BFG KDW's on Volk Rims
Old Feb 13, 2007 | 08:44 AM
joekool's Avatar
joekool
Default BFG KDW's on Volk Rims
Hi guys, I was just wandering if the Tires will fit on my Volk rims without any issues. The model and sizes for the rims and tires are as follows:
Rims:
Volk Progressiv spoke
Front: 19x9.5 +22
Rear: 19x10.5 +25
Linky: http://www.wheelspecs.com/specs/wheelmodels/3185
Tires:
BFG g-Force T/A KDW
Front: 255/35
Rear: 285/35
Linky: http://www.bfgoodrichtires.com/overv...-a-kdw/22.html
The KDW's aren't available here in Australia and I am importing them through www.tirerack.com so it's important that they are right for my rims.
thanks heaps.
Martz
Old Feb 13, 2007 | 08:56 AM
JRoC's Avatar
JRoC
Yes they will fit no probelm at the moment I have:
18x8.5 with 255/35/18
18x11 with 295/35/18
The rear will look streched alil but you should be just fine
Old Feb 13, 2007 | 09:02 AM
DavesZ#3's Avatar
DavesZ#3
Yes, they should fit fine and there really won't be any stretch on the rears. Most people are running 245/275 tires and those are a little stretched.
I'm running essentially the same setup except with LE37Ts (9½/10½ wheels with 255/285 PS2 tires) and the fronts and rears fit fine. One of the reasons I picked 255/285 vs the 245/275 was to make sure there was enough "tire" to provide a little extra protection to the lip on the wheel.
Old Feb 13, 2007 | 09:41 AM
redlude97's Avatar
redlude97
Did you look at the KDW2's? They are an overall better tire
Old Feb 13, 2007 | 09:44 AM
redlude97's Avatar
redlude97
Wait, did BFG change the change the name from KDW2 to KDW? Tirerack still lists both kinds, but your pic says KDW, but shows a KDW2 treadpattern
Old Feb 13, 2007 | 02:44 PM
DavesZ#3's Avatar
DavesZ#3
KDW2 is the new version of the KDW tire.
Old Feb 13, 2007 | 02:49 PM
xedes's Avatar
xedes
I was told running 255/285, I would need to get my fenders rolled.....is this not true? ( i'm lowered with Hotchkis springs)
Old Feb 13, 2007 | 03:17 PM
redlude97's Avatar
redlude97
Take a look at the pic from his link http://www.bfgoodrichtires.com/overv...-a-kdw/22.html
It says KDW, but its a picture of a KDW2 right? Thats where I got confused
Old Feb 13, 2007 | 03:50 PM
plastiketa's Avatar
plastiketa
I'm running F 245/35/19 R 285/35/19 on my F9.5/R10.5. The 245 have a bit of stretch (I originally wanted 255) but the rears are perfect. I rolled my fenders just in case. The rears do rub when I go up a curb, but not much.
Old Feb 13, 2007 | 10:44 PM
Volk350Z's Avatar
Volk350Z
Master
FYI -- BFG tires are wider then normal tires.. I had a set of TE37 19x9.5 +22 & 19x10.5 +22 with KDW 255/35 & 285/35 with Tein Flex and my rear needed to be trim..
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
