offset / spacers question
Old Feb 18, 2007 | 11:47 PM
Boneout JZA80's Avatar
Boneout JZA80
Shine Auto Project
Default offset / spacers question
i have some wheels 19 x 9 / 19 x 10 with +45 offset, whats the biggest (hubcentric) spacer i can go with 25mm or 30mm? i wanted to make it look pretty aggressively flushed. i really need help on this because im probably going to get the spacers this week. thanks alot folks also anyone know where to get spacers i was think H&R, Project Kics or Ichiba(dont know about them but theyre local)... thanks again
Old Feb 19, 2007 | 12:17 AM
Volk350Z's Avatar
Volk350Z
Master
I would do 30mm that's will put you at 9.0/10.0 +15 which is no problem..
Old Feb 19, 2007 | 07:56 AM
Boneout JZA80
Shine Auto Project
awesome Bryan ill take that into consideration
what are the offset on your magnesium TE's if you dont mind me asking?
thanks again
Old Feb 19, 2007 | 09:10 AM
97supratt's Avatar
97supratt
I'd say 30 as well. I have 25mm H&R's in the rear on my 30 offset and it looks amazing.
Old Feb 19, 2007 | 10:44 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
thanks again
+22.
Old Feb 19, 2007 | 11:25 AM
Volk350Z's Avatar
Volk350Z
Master
^^^ yup ^^^
Old Feb 19, 2007 | 02:55 PM
Boneout JZA80
Shine Auto Project
cool fellas thanks for the feedback
Old Feb 19, 2007 | 05:35 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
make sure you put tire size into the equation - that will determine what, if any, body mods you will need
and make sure you've got a way to adjust camber and especially toe out back - you are going to have gobs of toe in with that low of an offset
Old Feb 19, 2007 | 06:21 PM
Cheezwiz's Avatar
Cheezwiz
Would a 10mm spacer throw off toe too much?
I'm looking at some 17x8 wheels with a 35mm offset, but I wanted a pair of spacers for the rears.
Oh, btw. How do you set the torque on the type 4 spacers Here
Old Feb 19, 2007 | 08:14 PM
cubu's Avatar
cubu
can someone explain to me how toe is effected by spacers? i have 40mm offset in the rear and just put on 25mm spacers... will i need to buy the parts so i can adjust toe and camber?
Old Feb 20, 2007 | 04:37 AM
Z1 Performance
Former Sponsor
in its most simple form, setting the alignment is setting the relative position of the tires to the ground. Any issues that exist with stock wheels and tires (such as exceessive camber due to lowering, or excessive toe), are now even further exaggerated as you move the wheel farther and farther out on the axle. Fit wider wheels and tires, the problem is exaggerated even more.
Again, no one can tell you "how much" a given setup willl throw you off, as no one knows what your alignment specs are before you start altering things. The only way to know is measure, make your mods, measure again, and then use something like the SPC kit to bring things back into spec. It's got more than enough adjustment that I've yet to find a wheel/tire combo it could not correct for
Mattg350z
Oct 2, 2015 06:51 AM
