Got the new wheels on
Old Feb 20, 2007 | 04:27 PM
MR_X's Avatar
MR_X
Default Got the new wheels on
Got me a set of TE-37s 19x9.5 +22 all around with some Dunlop SP9000. Sorry for the crappy pic. As soon as I get my suspension installed I will take some more glamorous shots. Also little bit consern about my tire size. 265/30-19 rear, 245/35-19 front. The tire design makes the side look smaller. So I want to use the crap out of this before I change them. I'm wondering if I can fit 275/30-19 all around with this rims size on a different brand of tire. Don't want the staggered set up.
Old Feb 20, 2007 | 04:37 PM
davidf's Avatar
davidf
The fronts are livable, but you could go 255/35's. For the rears I go 275/35's. That should do you.
Takhteh's Avatar
Takhteh
From the pic, the rear sidewall does look a little bit smaller in the rear. But so what? Run the hell out of them and then get new ones, the same all around like you said. But I think 265 all around might even be better, though. I'm getting 9.5" wide wheels also and am debating between 265/275 all around. I just don't think you would want that wide a tire to be up front.
Old Feb 20, 2007 | 04:44 PM
THE TECH's Avatar
THE TECH
Looks like an offroad vehicle. TE's are always a classic. Just needs some suspension and you're good to go.
Old Feb 20, 2007 | 04:49 PM
05-Z's Avatar
05-Z
I thought it was a photoshop for a minute.
Old Feb 20, 2007 | 05:11 PM
MR_X's Avatar
MR_X
Well don't want to use the front because it looks stretched out and the rims is sticking out further than the tire and I want to go the same size all around. I would like to go with 265/35-19 but is a hard to find size tire. I know Tire Rack carried them but there is not that much of a selection on that size, reason why I want 275s because they are every where. So should I go with 275/30-19 or 275/35-19 all around?
Old Feb 20, 2007 | 05:24 PM
Takhteh's Avatar
Takhteh
this might be a stupid question, but does a 265/30/19 tire have less treadwear than a 265/35/19?...or is the sidewall height just smaller and w/same tread?
If both are the same, I'd probably go for the 265/30/19 if running the same all around.
Old Feb 20, 2007 | 05:30 PM
MR_X's Avatar
MR_X
I would think the tread wear depends on the type/brand of tire. I want to steer away from 265/30 or 35 all together.
Old Feb 20, 2007 | 05:36 PM
black06z's Avatar
black06z
for some reason, the sidewall look way too skinny.
Old Feb 20, 2007 | 05:42 PM
Nihilation's Avatar
Nihilation
You need to run a 35 series rear tire. The 30 series sidewall is waaaayyy too small. Look at wheel diameter. You want to get as close to a 26.5" tall as you can in the rear. Those rear tires are probably 24" tall which is why they looks so small. If it was me I'd run 275/35/19's all around. You really should get that corrected asap.
Old Feb 20, 2007 | 05:43 PM
bb1314's Avatar
bb1314
da Terminator!
Is there a reason why you got 19x9.5 all around instead of the staggered setup? Personally I think the staggered setup looks a lot better.
Old Feb 20, 2007 | 05:49 PM
MR_X's Avatar
MR_X
So it is set, 275/35-19. Going to use the crap out of this and replace them with a set of Toyos T1R.
I got a good deal on this and I wan to have the capability to rotate tires. I also don't like understeer.
mx22o's Avatar
mx22o
nice..
Old Feb 20, 2007 | 05:53 PM
Takhteh's Avatar
Takhteh
GL with the 275's. I'm still debating 265/275, but also wanted the ability to rotate the tires, etc..Let us know how it works out for you and give us some more PICS!!
Old Feb 20, 2007 | 06:15 PM
Volk350Z's Avatar
Volk350Z
Master
wow the wheel gap is huge..
Old Feb 20, 2007 | 06:23 PM
MR_X's Avatar
MR_X
the wheel gap ia also because where the car is at.
So any one has a very good hook up for tires?
Old Feb 21, 2007 | 06:05 AM
davidf's Avatar
davidf
I use Tire Rack but last time I did discount matched their price. BTW I did'nt realize you "did not" want staggerd when I posted.
Old Feb 21, 2007 | 06:14 AM
crewmsu5's Avatar
crewmsu5
Congrats on joining the TE37 club! TE37s have more fun!
Old Feb 25, 2007 | 02:18 PM
hockiman90's Avatar
hockiman90
has anyone heard anything about the 275's up front?
Old Feb 25, 2007 | 02:20 PM
MR_X's Avatar
MR_X
I did a search and found some one running 275s all around with the same rim
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
