Post your tire/rim set up
Old Feb 28, 2007 | 12:23 PM
Ken@Performance's Avatar
Ken@Performance
Performance Nissan
SSR GT2H
tire sizes: 275/30/19fronts // 305/30/19 rear
wheel size & offsets: 19x9 +31 F 19x10.5 R +43 however added a 15mm spacer so I guess it is now a +28
suspension mods: Hks hypermax damperII coilovers
how much lowered: alittle over a inch in the front. Rear is about a inch.
camber: not sure.
rolled or not fenders: Was hammered abit for my previous wheels which was like 3mms.
Old Feb 28, 2007 | 05:02 PM
emulzhn's Avatar
emulzhn
Default any camber issues with your tanabe's
Originally Posted by NeverLift
tire sizes: 245/35/19 front & 275/35/19 rear
wheel size & offsets: 19x8.5 front 19x9.5 rear +22 offset
suspension mods: Tanabe GF210
how much lowered: 1" front / 1.2" Rear
camber: stock
rolled or not fenders: not rolled
saw that you had 1" and more for dropped effect, any camber issues, any addntl components to keep drop safe and non-problamatic with ride...
thanks..
gathering data for just spring mod. trying to stay away from added stuff. If I would need to add stuff, then justify it with coilovers..but price is 5-fold
Old Feb 28, 2007 | 05:23 PM
MR_X's Avatar
MR_X
Originally Posted by Ken@Performance
SSR GT2H
camber: not sure.
I almost got me a set of those wheels. got some pics?
Old Feb 28, 2007 | 09:09 PM
NeverLift's Avatar
NeverLift
thanks..
No camber issues. Everything was aligned back to spec I think, I'll have to find the printout they gave me.
Old Feb 28, 2007 | 09:28 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Wheel Size: 19x9 front; 19x10.5 rear
Wheel Offset: +31 front / +43 rear
Wheel Brand: SSR GT-2
Tire Size: 245/35/19 & 285/35/19
Tire Brand: Goodyear Eagle F1 GS-D3
Suspension: OEM
Security: Gorilla Wheel lock & Gorilla Tuner locking lug nuts! 2 different key set is needed to steal these so hopefully it will deter the thieves a bit.
Old Feb 28, 2007 | 09:29 PM
plumpzz's Avatar
plumpzz
tire sizes: 245/40/18 front & 275/40/18 rear
wheel size & offsets: 18X9 front +20; 18X10 rear +18
suspension mods: Tokicko D spec spring/shock kit.
how much lowered: 1" front / Rear
camber: stock
rolled or not fenders: needs to be rolled.
Old Mar 1, 2007 | 05:58 AM
Takhteh's Avatar
Takhteh
camber: stock
Did you roll both front and rear fenders?
And how much clearance in your set-up between tires and camber arm, fender, etc.. if you can give just a rough estimate? Thx.
Actually, maybe never mind bc I just saw you had suspension mods...
Old Mar 1, 2007 | 06:01 AM
plumpzz's Avatar
plumpzz
The tire/wheel clears all hardware. Just need to roll the fender. Im going to get them rolled today.
Old Mar 1, 2007 | 06:02 AM
Takhteh's Avatar
Takhteh
Still...front and rears?
Old Mar 5, 2007 | 12:11 PM
yellowlady's Avatar
yellowlady
Default bad set-up
i just got the car a few weeks ago and i think there is a problem with the tire set up. the fronts are hankook 245/35/19, and the rears are generals 275/30/19. the car is an 05 touring with a manual tranny. when i am driving hard into corners one of the front wheels fells like the abs is being activated for that one wheel even though i may not be on the brakes. it happens maybe once a day under hard conditions, but it does freak me out a little.
my rear tire seems to be to small while the front is the same diameter as the stock size. i think i will be getting some new goodyears with fronts the same size and rears 275/35/19
Old Mar 5, 2007 | 12:31 PM
plastiketa's Avatar
plastiketa
tire sizes: 255/35/19 front & 285/35/19 rear
wheel size & offsets: 19x9.5 front +26 offset 19x10.5 rear +29 offset
suspension mods: KW Varient 3, Stillen Sways, Kinetix Toe & Camber Arms, SPC Toe Bolt
how much lowered: Not sure, but its to the top of the tires
camber: not sure, will find out soon
rolled or not fenders: rolled
bbk: OEM Brembos 4f/2r pots
Old Mar 5, 2007 | 02:37 PM
Lightning Guy's Avatar
Lightning Guy
tire sizes: 275/35 front & 295/35 rear
wheel size & offsets: 18x9 front +34 offset 18x10 rear +44 offset
suspension mods: RSR springs, Hotchkis sways
how much lowered: 0.6"
camber: stock
bbk: OEM Brembos
