NO flaming, i just want some answers i cant find
Old Feb 28, 2007 | 06:36 AM
ke0ki2k's Avatar
ke0ki2k
Default NO flaming, i just want some answers i cant find
so again to the weight issue. is a 22 pound wheeel that is 18x10.5 heavy? i know there are 18x9.5's that weigh like 18-19 pounds but, are there any 10 or 10 & 1/2 inch wide tires under 20 pounds? & with a stock suspension i can run 265/35 on the 9.5 inch fronts, and 295/30's on the 10.5 inch rears with no rubbing issues? (im goin to wait a while before getting some revalved konis & putting T2 springs on em)
Old Feb 28, 2007 | 08:14 AM
MustGoFastR's Avatar
MustGoFastR
The Volk TE37 is a real lightweight (around or under 20lbs) and can be had in 18x10.5. No idea on your rubbing question.
Old Feb 28, 2007 | 08:18 AM
The weight is relative. Generally a forged wheel will weigh less than a cast wheel. Manufactures such as SSR and WedsSport use a different technique to reduce weight. Just check the wheels and compare weights.
Old Feb 28, 2007 | 09:45 AM
CEO350Z's Avatar
CEO350Z
That's bad juju
you should pm some of the wheel sponsors. they'd probably know alot more about it than the average forum member.
as for rubbing, i'd just cut the fenders. it allows room for future tire sizes.
Old Feb 28, 2007 | 09:48 AM
push's Avatar
push
Rubbing will depend on your offset and tire brand\model.
Old Feb 28, 2007 | 12:56 PM
ke0ki2k's Avatar
ke0ki2k
*cough*....TE37's are like 4 grand for a 10.5 rear 9.5 front staggered setup man lol ive found the 10.5r9.5f reverb setup for 1300...& theyre what, 2 pounds heavier per wheel? i mean Sh*t...im all for performance but im not racing lemans or somethin
Old Feb 28, 2007 | 01:07 PM
Sean's Avatar
Sean
Great quote
Old Feb 28, 2007 | 02:04 PM
redlude97's Avatar
redlude97
Its not just weight, the volks are forged, so they are way stronger than the cast reverbs. They also come in better offsets that aren't available on the reverbs. If Axis wheels are good enough for you, then get them, just don't try to make a comparison to Volks
Old Feb 28, 2007 | 04:18 PM
ke0ki2k's Avatar
ke0ki2k
lol gettin defensive, im not comparing em as equals but d*mn dude, if you're slappin 4k worth of performance wheels on you better be racing for money or something.
Old Feb 28, 2007 | 04:33 PM
Nihilation's Avatar
Nihilation
Check out the Enkei RPF1's they are available in 18x10.5 and most likely 20lbs or less.
Old Feb 28, 2007 | 04:44 PM
redlude97's Avatar
redlude97
Defensive? I don't even own Volks.... Based on your logic, why drive a Z when you can get almost the same perfomance driving an integra for less money, its not like you are going to track either one
Old Feb 28, 2007 | 05:17 PM
MR_X's Avatar
MR_X
what I know is that my rear Volks TEs that are 19x9.5 w/ 265/30-19s are lighter than the original 17" w/ 235/50-17.
BTW I got my Volks w/ tires for $2k
Old Feb 28, 2007 | 06:11 PM
Tubbs's Avatar
Tubbs
What Volks cost 4k??? Magnesium?
Old Feb 28, 2007 | 07:39 PM
Volk350Z's Avatar
Volk350Z
Master
where did you find a set of volk 18" for $4000?? wtf..
if you want chaep wheels then don't expect it to be light and strong.. any company can make a light wheel but this might happen when you hit a pot hole..
Old Mar 2, 2007 | 02:53 PM
ke0ki2k's Avatar
ke0ki2k
lol no more responses for you...TE37's are a lil out of reach price wise...& what the hell are you talking about same performance from an integra? or are you one of those that sticks to the strips only? id guess so...Z's arent made for strip use m8 theyre made for road courses...hence why track edition Z beat the evo IX MR around virginia international...take your rice & join a forum where they dont care about cornering or handling
Old Mar 2, 2007 | 02:54 PM
ke0ki2k's Avatar
ke0ki2k
& yeah the TE37 volks 18x10.5 rear 18x9.5 front were like 3800 bucks man...ive looked around nobodys cracked a reverb...Axis uses them on their track cars so they obviously dont crumble or anything...regardless they probably have a warranty...if it cracks i could threaten to file a lawsuit & theyd send me a new one
Old Mar 4, 2007 | 03:34 PM
dan avoN7's Avatar
dan avoN7
and if you hit a pothole with a forged rim this will happen
Old Mar 4, 2007 | 05:04 PM
PDX_Racer's Avatar
PDX_Racer
In wheels, the following applies:
  • Light
  • Strong
  • Cheap
Pick any two.
Old Mar 4, 2007 | 05:15 PM
ke0ki2k's Avatar
ke0ki2k
if you crack a wheel couldnt you like sue them for wreckless endangerment or somethin tho? or wouldnt they replace it to avoid a lawsuit like that?
Old Mar 4, 2007 | 05:33 PM
Zexy's Avatar
Zexy
Yeah but the difference is that is repairable and doesn't crack. That's fixable.
Good point!!
