Rub or not Rub..
Old Mar 5, 2007 | 10:33 AM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
Default Rub or not Rub..
simple answer yes.. or no..
GT-S 19" F17, R18 with T1R
Stock Suspension
1. F 245/35/19
2. F 255/35/19
3. R 275/35/19
4. R 285/35/19
thanks
Old Mar 5, 2007 | 10:43 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
245/35 - No
255/35 - No
275/35 - Slightly, depends on how low you are
285/35 - Yes
Theres no need to go with a 285 on the rear if you are not making FI power. Stay with a 275 for the rear and roll the fenders. Go with a 255 front.
Old Mar 5, 2007 | 10:46 AM
behjjeh's Avatar
behjjeh
Originally Posted by Andy@Performance
245/35 - No
255/35 - No
285/35 - Yes
thanks for the input~
even with stock suspension i need to roll the fenders?
Old Mar 5, 2007 | 11:49 AM
redlude97's Avatar
redlude97
245/35 - No
255/35 - No
285/35 - Yes
Going with a 285 isn't just about performance, some prefer the non stretched look of a tire and the extra rim protection it provides. I say go 285 and roll, its not a big deal
Old Mar 5, 2007 | 11:52 AM
bam025's Avatar
bam025
I had 285's on stock suspension and didnt have to roll. When I put my springs on then I definetly had to get my roll on.
Old Mar 5, 2007 | 11:54 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
245/35 - No
255/35 - No
285/35 - Yes
I don't agree with this statement. 285s on the rear looks a lot better than 275s. Also, if you are running 10.5s on the rear the 275s will have that stretched look. IMO it's not proper fitment. Also, the offset and the tires you select will affect your clearence. Not every tire of the same size will have the same dimensions. Either way though it's best to roll.
Old Mar 5, 2007 | 11:55 AM
redlude97's Avatar
redlude97
with a 10.5 +18 wheel? any pics?
Old Mar 5, 2007 | 11:59 AM
JDMFairladyZ33
I'm not dropped yet and I have to run 285/30/19s so that I won't rub. Once I am dropped I am moving to 285/35/19s and have to roll and do a 50% cut on the inside of my fenders.
See how far out +18 pushes the wheels? They sit right over the fenders:
This is the clearence on 285/30/19s:
Far shot:
3/4 rear:
Old Mar 5, 2007 | 12:00 PM
bam025's Avatar
bam025
Sorry no pics at that time...however my rear was +23 or +24
Old Mar 5, 2007 | 12:20 PM
redlude97's Avatar
redlude97
I don't see how your post pertains to the subject then, we are talking specifically about a 10.5 +18 setup, its already widely known that a 285 will fit with the correct offset
Old Mar 5, 2007 | 12:22 PM
redlude97's Avatar
redlude97
Thats what I figured, I didn't think there was any way you could get away with 285/35/19 +18 without a roll
Old Mar 5, 2007 | 12:24 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
19 x 10.5 +17 on 285s with stock suspension WILL rub. and it will rub real bad. my tires got shredded pretty bad.
Old Mar 5, 2007 | 12:28 PM
JDMFairladyZ33
The rears should be +18 and the fronts +17. +17 on front with 255/35/19s are not a problem. If you were running 285/35/19s yes I agree with you. That is why I had to start with 285/30/19s.
Old Mar 5, 2007 | 12:29 PM
JDMFairladyZ33
BTW 285/35/19s are the correct plus sizing application. It keeps the correct inflated rolling diameter at 285. 285/30/19s are a bit shorter but I'm not having any issues with VDC.
Old Mar 7, 2007 | 07:50 AM
behjjeh's Avatar
behjjeh
so.. no need to roll my fender if i get 285 30 19 in the back?
Old Mar 7, 2007 | 10:55 AM
redlude97's Avatar
redlude97
If you are stock height no, but its the wrong tire size for the car, 285/35/19 is the right size. Its better to use the right sized tire and roll rather than run the wrong sized tires to prevent rubbing. You will still rub on extreme compression though, because in essence all you are doing is increasing your fender gap by using a smaller tire so the fender is further from the tire, but the width will still cause rubbing
Old Mar 7, 2007 | 12:38 PM
JETPILOT's Avatar
JETPILOT
A 295/30/19 would be a better tire choice for the rear.
A 275/30/19 would be the best tire choice for the front.
JET
Old Mar 7, 2007 | 01:12 PM
Vertex350's Avatar
Vertex350
I have 285/35/19s on the rears with my fender rolled. I would stick with 275/35/19 if you don't want to roll and you don't plan to drop it.
416blueZ
Jun 11, 2024 10:56 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
hulkout
Apr 28, 2017 09:00 PM
416blueZ
Sep 24, 2015 02:11 PM
waldo36
Sep 20, 2015 09:13 PM
