different tire F/R question
Old Mar 21, 2007 | 12:58 PM
rrdugas's Avatar
rrdugas
Default different tire F/R question
I just had my new warranty covered potenzas put on the front they are the RE040 that i had before. I need to replace my rear tires and i just wanted to change to the RE050a series.
Do i have to run the same tire front and rear or is it ok to switch em out? I'm no tire expert obviously so i don't know how this would affect wear and handling.
Old Mar 21, 2007 | 02:34 PM
No.
A minor problem is that tires are tested on all corners. Handling is predictable. When you mix and match, the outcome is uncertain. Unless you are a professional driver, I doubt you will notice anything negative.
Old Mar 21, 2007 | 02:57 PM
f00man88's Avatar
f00man88
Just pay attention to speed ratings. cant mix those. re 040's are w which is rated for around 140 if im not mistaken. as the above ^ poster said be aware that it could cause uncertainty.
Old Mar 21, 2007 | 03:00 PM
f00man88's Avatar
f00man88
On a side note. that was very broad you shouldnt mix diffrent brands either or tread patterns. good luck
Old Mar 21, 2007 | 03:10 PM
kbomb's Avatar
kbomb
I thought you can mix tire brands?
as long as you keep the front tires same brand and the rears same brand.
Old Mar 21, 2007 | 05:06 PM
f00man88's Avatar
f00man88
You can. just make sure your speed ratings are the same temp traction etc etc. I just personally wouldnt. but if you are going to mix match brands you are corect do in sets of 2 either front or back same brand dont put 2 diffrent brands on the LR and RR. But on a 40 thousand doller car why risk it? If you own a 350z Your more then likely have enough to keep the right tires on your car???
Old Mar 21, 2007 | 10:56 PM
Bevo's Avatar
Bevo
yes, you can mix them up. however, it's recommanded that you run the same tires all around
Old Mar 21, 2007 | 11:40 PM
rrdugas's Avatar
rrdugas
thanks for the help... i didn't mean i wanted to run a different brand front and back.. and both versions of the potenza's are the same speed rating
http://www.tirerack.com/tires/Compar...rearWidth=245%
heres a comparison of what i'm looking at. i allready have the 040's on the front and want the 050's on the rear
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
