5x114 to 5x120
Old Mar 26, 2007 | 07:55 AM
dragone2717's Avatar
dragone2717
Default 5x114 to 5x120
i found a nice set of 20's for a damn good price. But they are 5x120 bolt pattern. Anyone one have a clue how I can get these on?
Old Mar 26, 2007 | 08:07 AM
sry110's Avatar
sry110
My *uneducated* guess would be that you will need to swap out your existing hubs for ones with the studs spaced on 5x120 pattern. Whatever money you save when buying the wheels for a good deal, you will pay to swap out the hubs.
Old Mar 26, 2007 | 08:54 AM
bizzyboyZ's Avatar
bizzyboyZ
dude there's no way you can fit that on your car, 5x120 is for BMW
Good Luck
Old Mar 26, 2007 | 09:24 AM
dragone2717
BUmmer.... Where else can I get a set of Lowenharts with tires for 700??????
Thanx guys
Old Mar 26, 2007 | 09:45 AM
MR_X's Avatar
MR_X
goggle it. you can find them. They are the same thing as wheels spacers with studs on them (which you will needs since BMW has a high offset).
Old Mar 26, 2007 | 09:46 AM
NoahzBurnt's Avatar
NoahzBurnt
idepending on the wheel a 5x114.3 pattern may be able to be drilled in the spaces between the 5x120 holes.....only $25 a wheel in most cases....don't know the wheel so I cannot comment of this can be done or not
Old Mar 26, 2007 | 09:51 AM
jtabraham's Avatar
jtabraham
You can definitely make that wheel work:
http://www.wheeladapter.com/wheel_ad...el_spacers.asp
Get a bolt pattern adapter and spacer in one machined piece.
Old Mar 26, 2007 | 10:51 AM
dragone2717
Whoa. Just found out the 20's are a 5x120.65. Thay are coming off a 98 Jag XK8
Old Mar 26, 2007 | 03:23 PM
joe645733's Avatar
joe645733
why would u put 20" on a 350z? its not a rapper car and DUB doesnt make an edition of it.
if youre going to do that, u might as well just put spinners on it
Old Mar 26, 2007 | 04:22 PM
shinkuu's Avatar
shinkuu
im with you on that one but to each his own
Old Mar 26, 2007 | 07:49 PM
dragone2717
Hey thanx for the idea. I'll make sure to credit you on that.......
RavSpec
Aug 20, 2020 07:01 AM
VarrsToen
Apr 18, 2013 04:39 PM
RavSpec
May 14, 2011 10:38 AM
TheMambanator24
Jan 20, 2011 12:19 PM
