Rear Tires Installment Charge
Old Mar 28, 2007 | 08:23 AM
yukonlikmiballs's Avatar
yukonlikmiballs
Default Rear Tires Installment Charge
I asked discount tire how much they would charge to put on 2 rear tires that i have worn out.. They told me it would be between 60-70 bucks because the z's have some sensor in the wheels they have to adjust. Does this sound like a rip to anyone else?
Old Mar 28, 2007 | 08:28 AM
Blacryan's Avatar
Blacryan
No. The Z's have Tire pressure sensor's (TPS) in the wheels. They work with the Tire Pressure Monitoring system so you know if your pressure is low in your tires!That does sound a tad bit high though. They charged me like 90 to do all tires at nissan and les schwab wanted like 75-80 to do all 4.
Old Mar 28, 2007 | 08:57 AM
DavesZ#3's Avatar
DavesZ#3
YES, it's a ripoff. While most if not all Zs have the TPS installed in each wheel, there's nothing that needs to be adjusted or changed when swapping tires. All you do is dismount the old tire and mount a new one.
As long as they keep the wheels on the same corners they came from, their shouldn't be a problem with keeping the TPMS working properly.
Old Mar 28, 2007 | 11:31 AM
donut_ballz's Avatar
donut_ballz
Doesn't sound like a rip off. Because if you go to their website and purchase thier tires, its $12.95 per tire for install and lifetime balancing..then i think its $4 per tire for the TMPS service.
Old Mar 28, 2007 | 11:54 AM
Some tire shops will not will work wheels with TPMS sending units inside. Other shops will not work on big (19 inch wheels). The shop risks paying for any damage. I suppose $70 helps offset the cost of buying owners sending units that they have broken in the past.
Old Mar 28, 2007 | 12:17 PM
donut_ballz
i needed some tires too. I just called them and they also do price matching! But about the TPMS I asked the rep about that and he said if they have to remove the valve and the rubber grommet that is on it to release the air that they will have to be replaced. And he said they usually charge 8-9 bucks per tire.
Old Mar 28, 2007 | 12:40 PM
Ztalker's Avatar
Ztalker
Big O charged 22$ per tire(mounted/balanced) with TPMS...a 5$/tire disposal fee is also included.
Old Mar 28, 2007 | 12:50 PM
SOCAL350's Avatar
SOCAL350
If you use discount..........inspect your wheels before you leave. Take it from a old discount manager. Some of those kids have no business touching certain types of wheels.
Old Mar 28, 2007 | 01:05 PM
donut_ballz
now that doesnt make me wanna use discount tires for installation
Old Mar 28, 2007 | 01:39 PM
SOCAL350's Avatar
SOCAL350
If you find the right guy im sure it does not matter where you go. Nothing against discount because there is a tier of very qualified employees but ive seen some bad stuff in my day. I will save the horror stories for the camp fire.
Old Mar 28, 2007 | 02:54 PM
Spike100's Avatar
Spike100
I just had two rear tires (Goodyear Eagle F1 GS-D3/ 245/45/18) installed. I paid $15 (including a $5 disposition fee) per tire ($30 total) to mount and balance the two rear tires. I have TPMS sensors in the wheels, but they didn’t need to do anything with these.
--Spike
hulkout
Apr 28, 2017 09:00 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
