just want to double check...
Old Apr 3, 2007 | 08:22 AM
dkorr's Avatar
dkorr
Default just want to double check...
tires: 225/45/18 front .... 245/45/18 rear
wheels: 18x8 +20 front .... 18x9 +20 rear
is this a safe set-up?
also is TPMS installment required?
Old Apr 3, 2007 | 09:13 AM
bbs350z's Avatar
bbs350z
i would assume so...tire may need 2 b stretched which affects performance
Old Apr 3, 2007 | 09:23 AM
THE TECH's Avatar
THE TECH
Technically it is illegal to remove the TPS from the vehicle.
It is also adviseable to keep them as well if you don't want warning lights and buzzers to come on in the car.
Old Apr 3, 2007 | 09:39 AM
dkorr's Avatar
dkorr
so if i buy aftermarket wheels its mandatory to buy another set of tpms as well?
Old Apr 3, 2007 | 09:46 AM
bbs350z's Avatar
bbs350z
no, theres a diy onthe boards sumwhere here.
Old Apr 3, 2007 | 09:49 AM
THE TECH's Avatar
THE TECH
No just put your stock ones on the new wheels. Simple as that.
Old Apr 3, 2007 | 11:45 AM
dkorr's Avatar
dkorr
yes that would be the simple thing, except i'm planning on keep the tpms on the stock wheels. i did find the DIY article on tpms. but lets get back to the main question.... is this a safe setup?
Old Apr 3, 2007 | 02:10 PM
VDC will be happy with these numbers.
Old Apr 3, 2007 | 02:43 PM
redlude97's Avatar
redlude97
its safe, but why not go wider on the tire size? 245/40/18 and 275/40/18 would be a better fit, and provide better handling
Old Apr 3, 2007 | 02:57 PM
dubbzdiggler's Avatar
dubbzdiggler
Dood, go with wider tires...like Redlude97 suggested...there are a TON of different options available from cheap to higher end...like most guys on here though, don't cheap out for the toyos, ha ha! JK, go with what you like.
Old Apr 4, 2007 | 04:06 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
that is an ultra conservative setup that really is not going to look like most people's cars here
You should be looking at an 18x9 all around, or 18x8.5 front (minimum), and at least a 9.5 out back
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
jlb
Oct 15, 2017 05:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
