Are Volks TE37 can be reconditioned?
I got a set of Bronze TE37 and I have two curb rashes on the Bronze lip..Its not big but I like everything to be perfect...are they reparable or not? Thanks.
the forged 1 piece wheels are powdercoated.
yes, they can be repaired, but how... i really have no clue. could be aluminum welded and machined, however the powder coating to exact color is in question.
Any wheels can be reconditioned. The labor is intensive and expensive. You have to decide if it worth the expense. Where is a good place to have wheels reconditioned? Ask in your regional forum.
Forget matching the color...I checked and Volk doesn't release the paint code for their wheels. I have an inch curb on mine and I'm gonna wait to refinish all four. So, if you're gonna repair them, do it all the way and repaint/powdercoat all four to match the color. .02 cents included....
when they do that wheel repair / reconditioning, don't they heat it up to a very high temperature? Does this weaken forged wheels such as volks?
I've seen wheels being repaired by an excellent wheel shop here in the Denver metro area. They spin it on a wheel lathe and check runout on the wheel. If it's within spec, they use a fixed blade to save away a small bit of the curbed lip as the wheel spins. They can't take off too much material, but if it's a light rash, it cleans up nicely.
This type of repair usually leaves behing a clean section of metal. Hopefully a silver wheel just needs a light clearcoat to match the sheen. But a powdercoated wheel is impossible to color match.
Good luck!
Good luck!
repair and color stripping doesn't involve heat, but involves machine and chemical work.
powder coating involves baking the sprayed product in an oven up to 400 degrees fahrenheit. i doubt the baking will reduce the integrity of the wheel.. i mean, rays do it to their wheels, why can't it be done anyways? besides, i don't think 400 fahrenheit is high enough to destroy the wheel as the melting point of aluminum is around 1200+ fahrenheit.
found a shop that'll repair AND powdercoat my wheels at 75 bucks a wheel. now that's a steal!
anodization will leave a lustrous metallic hue, as the dye is translucent over bare aluminum. powder coat is same as paint... opaque and the shine will depend on the coating itself. for a nice glossy look, can always clear coat over powder...
I did alot of research on this. no, powdercoating is not likely to cause issues... However, using bake-off oven to strip should be avoided, especially with forged wheels. Baking off a coating can reach 500F+, or higher if the operator isnt paying attention. Alot of wheels are so strong, even if they come close to that annealing temp, it will be ok. However, for very light wheels with thin spokes, well... you've seen the pics on the net. They can crack. Enkei isnt to keen to some of their wheels being recoated, or so I've read, but again I think its more avoiding baking off the original coat. The wheel can become more brittle, it 'ages' the wheel, so to speak.
bcoffee20
Nov 19, 2015 06:39 PM
