Anyone get their fenders rolled?
Old Apr 19, 2007 | 03:22 PM
DIGItonium's Avatar
DIGItonium
Question Anyone get their fenders rolled?
Body shop called about the rear fenders, and they couldn't roll it without the paint cracking. They can roll it "flat" like the front fenders, but it'll require painting. The total cost with my bumper repair jumps from $820 to $1400! I had to avoid since I didn't plan on keeping the car too long.
Just wondering if anyone did this. I'm running 285/35r19 rubber with LE-37t +22mm offset.
Old Apr 19, 2007 | 04:45 PM
redlude97's Avatar
redlude97
I rolled mine myself without cracking anything. Make sure they use a heat gun and they should be fine
Old Apr 19, 2007 | 04:46 PM
GSoccer24's Avatar
GSoccer24
+1 on the heat gun, sounds like they're trying to make some extra $$$ off you maybe
Old Apr 19, 2007 | 05:00 PM
05-Z's Avatar
05-Z
does the heat gun prevent the paint from cracking?
Old Apr 19, 2007 | 05:06 PM
___DJK___'s Avatar
___DJK___
Get them shaved, should cost less than $100 and you dont have to worry about paint cracking.
Old Apr 19, 2007 | 05:10 PM
Phantom Menace's Avatar
Phantom Menace
There's a really good DIY here where someone used a PVC pipe & heat gun to roll their fenders. Although, I'd like a better (closer) look at the actual "rolled point," it looked fine from the pics.
We used to use baseball bats and blowdriers back when our cars were only worth $2-3k. With a $30k car...you have a very valid reason for pause before taking a pipe to your fenders. I know, I do.
Old Apr 19, 2007 | 05:22 PM
05-Z's Avatar
05-Z
^ found it
http://g35driver.com/forums/showthre...fender+rolling
Old Apr 19, 2007 | 05:46 PM
redlude97's Avatar
redlude97
I did it using ABS pipe, better than a baseball bat because it flexes only allowing a little roll at a time
Old Apr 19, 2007 | 07:28 PM
DIGItonium's Avatar
DIGItonium
Nice... but I'm not sure if I can risk it. I'll ask them about the heat gun technique. Otherwise, I'll probably opt out and deal with the minor rubbing until I decide on a new car.
Thanks guys!
Old Apr 19, 2007 | 07:50 PM
leemik's Avatar
leemik
mine are rolled and pushed out a little bit as well..
paint wont crack on a new car.. they are trying to take you for more money
run
Old Apr 19, 2007 | 09:00 PM
DIGItonium's Avatar
DIGItonium
Really? He says the paint was "bubbling" out due to stress and the lines of the car. They're already charging $160 for both sides, so I'm not sure why they'd complicate things. [sigh]
I'll keep you guys updated. I'll probably pick up my car tomorrow after having the rear bumper repaired and repainted.
Old Apr 19, 2007 | 09:38 PM
plumpzz's Avatar
plumpzz
Get them cut. Its much cheaper, you get more clearance, and as long as a little bit of the fender is lefton, it wont degrade structural integrity. I did that, and also painted the inside of the fender with anti oxidizing paint to prevent any rust.
Old Apr 19, 2007 | 11:27 PM
terrasmak's Avatar
I did my friends with a wood baseball bat last weekend and didnt have a problem with cracking. He car is getting repainted so we didnt bother with the heat gun. Either way it didnt crack.
Old Apr 20, 2007 | 04:49 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
run
Actually the paint will crack on a new car. I cracked my paint on my G35 in the rear using that method above. But its best to heat it up a lot. I didn't heat mine.
Old Apr 20, 2007 | 05:27 AM
DIGItonium's Avatar
DIGItonium
I called guy at the body shop. He says it's standard procedure by using a heat gun. When I told him you guys did it with a PVC pipe with no complaints, he was surprised. I'll send him the G35 link.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
