Work 18x10.5 +19, 18x10.5 +14
Old Apr 20, 2007 | 01:19 PM
drumma022's Avatar
drumma022
Default UPDATED - Work 18x10.5 +19, 18x10.5 +14 **Pics on Post #7**
They just came in ... are being mounted and balanced at the moment.
The Front and the Rear wheel are both un-boxed and there is a 112mm Lip the Rear!
Attached Thumbnails Work 18x10.5 +19, 18x10.5 +14-vsxx1.jpg   Work 18x10.5 +19, 18x10.5 +14-vsxx2.jpg   Work 18x10.5 +19, 18x10.5 +14-vsxx3.jpg   Work 18x10.5 +19, 18x10.5 +14-vsxx4.jpg
Old Apr 20, 2007 | 01:23 PM
kwiker's Avatar
kwiker
Shift_Dorifto
awww man, i was so excited...i thought you got them put on already.
edit: These are going to be so sick on your car...I'm not going to be able to sleep tonight.
Old Apr 20, 2007 | 01:24 PM
BloMyS14's Avatar
BloMyS14
What a tease! Lets see some installed pics.
Old Apr 20, 2007 | 01:25 PM
ppw350Zunit's Avatar
ppw350Zunit
sweet!!! what size tires are you running?
Old Apr 20, 2007 | 01:29 PM
drumma022's Avatar
drumma022
I was stupid busy today at work that I am so mad that I couldn't get them to the tire shop on my lunch break. I managed to slip away from work at 4pm and I am hoping that they can get it done before them close!
Tire size: 265/35/18 all around
Old Apr 20, 2007 | 01:35 PM
Vertex350's Avatar
Vertex350
Wow, can't wait to see them on your ride. Work wheels FTW!!!
Old Apr 20, 2007 | 04:37 PM
drumma022's Avatar
drumma022
Pics finally - I will be getting some better pics over the weekend when I wash the car (if it doesn't rain like today!)
Front CUSCO camber arms are set to "0" which is the same as a stock arm would be. Rear Battle Version camber arms are a few turns from factory setting. I am planning on lowering the front a little to match the rear and if I have time, I will be putting extended wheel studs (no specific reason.)
Old Apr 20, 2007 | 04:40 PM
andypandy's Avatar
andypandy
wow nice pics!
for some reason, since the wheels are contrasting the color of your car, they look like 19" wheels. regardless, looks very good!
Old Apr 20, 2007 | 04:47 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Love the wheels, hate the stretch, sick offsets though.
Old Apr 20, 2007 | 05:33 PM
kwiker's Avatar
kwiker
Shift_Dorifto
Yep, they are just as dope as i expected.
Old Apr 20, 2007 | 05:42 PM
HXS's Avatar
HXS
looks like 19s!!!
Old Apr 20, 2007 | 05:47 PM
doug's Avatar
doug
Originally Posted by hardy
looks like 19s!!!
thats because its the wrong tire size
Old Apr 20, 2007 | 05:49 PM
Motormouth's Avatar
Motormouth
oh lord.
Old Apr 20, 2007 | 07:11 PM
drumma022's Avatar
drumma022
Wrong tire size?! I have done plenty of research on this fitment and used it on the last set of wheels without any problems. The tire is NOT too narrow for the wheel width. VDC and ABS has no problem at all with the tire diameter. The only thing that may be wrong is that this wheel and tire combo does not suit the bandwagon.
Old Apr 20, 2007 | 07:15 PM
TimeAttkZ's Avatar
TimeAttkZ
Great choice on brand of tires .. I wish I had 18's so I could run the RT-615 azenis !
Old Apr 20, 2007 | 07:19 PM
kwiker's Avatar
kwiker
Shift_Dorifto
How many times is Ray going to have to explain that this size is good for 18x10.5 ... he has even posted a pdf from Falken stating that they recommend this size exactly. Every time he posts it turns into a thread about how he is using the wrong size, stretching is not safe, why didn't you stagger, blah blah blah.
Old Apr 20, 2007 | 07:24 PM
ATL_Red_G35's Avatar
ATL_Red_G35
Forget what other said man, those definitely look sick.
You don't have plan to go for BBK in the future???
Old Apr 20, 2007 | 07:40 PM
Beau's Avatar
Beau
Did you happen to check how much space is between the inside of the wheel and the upright on the suspension?
Old Apr 20, 2007 | 10:05 PM
Equinox's Avatar
Equinox
Looks badass man! I want 18x10.5 all around!
Old Apr 21, 2007 | 12:59 AM
ppw350Zunit
any rubbing up front?
