Lug Question
Old Apr 24, 2007 | 04:16 AM
OCZTrack's Avatar
OCZTrack
Default Lug Question
What's the difference between open end and closed end lug nuts?
BTW please don't just tell me that one is open and one is closed...
Old Apr 24, 2007 | 05:25 AM
z-u-later's Avatar
z-u-later
Well, I hate to tell you this but that's exactly what they are. Open ended lug nuts have no top on them, and closed ended lug nuts are covered.
Old Apr 24, 2007 | 05:26 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
That made my day.
Old Apr 24, 2007 | 05:31 AM
Nihilation's Avatar
Nihilation
Open ended lugs are generally used with extended wheel studs to ensure that they don't bottom out. Open ended lugs are lighter weight as well.
Old Apr 24, 2007 | 06:52 AM
OCZTrack's Avatar
OCZTrack
Yeah I pretty much figured that... I guess I can't picture a lug with no top on it. Got a picture?
EDIT: NM on the picture, I found one. Is there any advantage/disadvantage to having an open ended lug nut vice a closed ended one? Or is this just aesthetics/personal preference?
EDIT #2: LOL I didn't see the post above this one... Thanks for the insight.
Old Apr 24, 2007 | 07:24 AM
z-u-later's Avatar
z-u-later
I normally use the closed end lug nuts on my street setup. For the track, I use the open ended lug nuts so I can visually inspect the tightness on the lug nuts more easily.
Old Apr 24, 2007 | 10:58 AM
VO...'s Avatar
VO...
Administrator
IFor the track, I use the open ended lug nuts so I can visually inspect the tightness on the lug nuts more easily.
I'm curious, but how can one visually decipher how tight a lug is by looking at it?
Old Apr 24, 2007 | 11:15 AM
z-u-later's Avatar
z-u-later
You can see the studs thru the open end. For example, if the studs were flushed with the top of the lug nuts at some point (start of an autocross run, prior to driving on a long trip, etc.) and you noticed at a later time (while preparing for the next run, while refilling gas, etc.) that the studs are no longer flushed with the top of the lug nuts, then that's a sign that the lug nuts are loose and they need to be re-torqued. On a closed end lug nut, you will not notice this unless you physically check each one.
Old Apr 24, 2007 | 11:20 AM
VO...'s Avatar
VO...
Administrator
gotcha...
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
