VDC problem
Old Apr 26, 2007 | 08:25 AM
bwk's Avatar
bwk
Default VDC problem
hey guys.. just installed new rear tires on my rims.. 275/35r18.. when i left the shop my vdc kicks in @ 3500 in any gear.. i can drive with vdc off.. but cant go any faster than 50km with it on... anyone have this problem before? or have any ideas
Old Apr 26, 2007 | 08:29 AM
FRLDYZPIMPN's Avatar
FRLDYZPIMPN
I had the same problem when i was running 245/35 front and 275/30 rear. My rear had smaller overall diameter than my fronts. THis caused my vdc to go off every time. What series tires are you running in the front? IF your running 40 in front with 35 rears, than thats your problem.
Old Apr 26, 2007 | 08:30 AM
raycs7's Avatar
raycs7
tire matching size ~275x40x18 close to OEM
Old Apr 26, 2007 | 08:33 AM
MustGoFastR's Avatar
MustGoFastR
Yup, you got the wrong size tires. You should have 274/40-18. What size do you have in the front?
Old Apr 26, 2007 | 08:42 AM
bwk's Avatar
bwk
ohh ok.. i have 245/45r18 in the front.. just temp for now.. my front size is backordered.. have 255/40R18 ordered for the front.. hope this fixes my problem
thanks guys
Old Apr 26, 2007 | 08:46 AM
bwk's Avatar
bwk
i was told 255/40R18 and 275/35R18 was correct for my car by my dealer.. hope when my front tires come in this fixes my problem
thanks again guys
Old Apr 26, 2007 | 09:13 AM
DavesZ#3's Avatar
DavesZ#3
thanks again guys
Nope.
255/40/18 = 26" diam
275/35/18 = 25.6" diam
Front is way taller than rear. VDC will definitely have problems.
I see this problem over and over. The rear profile usually have to be the same or larger than the fronts. The only way a rear profile is going to work is if it's a really wide tire.
Old Apr 26, 2007 | 09:29 AM
The rear tires are 28 mm shorter than the front. Very common mistake.
Old Apr 26, 2007 | 09:52 AM
Nihilation's Avatar
Nihilation
It amazes me how a car dealership can be so ignorant of tire sizes.
Old Apr 26, 2007 | 10:00 AM
thanks again guys
The rear tires will be 11.5 mm shorter than the front. A simple tire calculator is smarter than I was told.
Old Apr 26, 2007 | 10:50 AM
FRLDYZPIMPN
Most of the time, not just tires.
Old Apr 26, 2007 | 11:57 AM
raycs7's Avatar
raycs7
If you switch your current setup front to rear you will not have the problem...
Old Apr 26, 2007 | 01:52 PM
DavesZ#3's Avatar
DavesZ#3
...but you will have the oversteer problem instead.
Old Apr 26, 2007 | 03:02 PM
LOL I am sure that it has been done before.
Old Apr 26, 2007 | 03:45 PM
lowrider's Avatar
lowrider
thanks again guys
tsk, tsk, tsk, tsk. The dealer is FOS
Lou
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
