235/35/19 on frond and 275/35/19 rear??
Old Apr 30, 2007 | 12:05 PM
ARLETOS 350Z's Avatar
ARLETOS 350Z
Default 235/35/19 on frond and 275/35/19 rear??
Hi,i am running already 235/35/19 ce28n 22offset on frond and rear 265/35/19 25off.
I am thinking if the vdc stuff can clear the 235/35 and 275/35/ compination.
Please help before i do any stupidy and buy 275tires.
Thanks in progress.
Old Apr 30, 2007 | 12:08 PM
thanh27's Avatar
thanh27
Research the web site. Lots of people either have the 245/19, 275/19 set up or 245 (255)/19, 285/19 set up. I don't think I've seen too many with your suggested 235/19, 275/19 format
Old Apr 30, 2007 | 12:13 PM
ARLETOS 350Z
i dont want to run 245 or more on frond,car will be slower.
Just 275 for better traction.If anyone has done it please help
Old Apr 30, 2007 | 12:16 PM
DBTRACK's Avatar
DBTRACK
Many People Have 275/35
Old Apr 30, 2007 | 12:20 PM
Tubbs's Avatar
Tubbs
you planning on turning too? or are you just going in a straight line everywhere?
Old Apr 30, 2007 | 12:22 PM
thanh27's Avatar
thanh27
On 19's? I gotta assume the front's are definitely not 9-9.5's then...
Old Apr 30, 2007 | 12:23 PM
DBTRACK's Avatar
DBTRACK
He means for the rear....
Old Apr 30, 2007 | 12:24 PM
scotts300's Avatar
scotts300
What diameter are the wheels? It matters.
Old Apr 30, 2007 | 12:25 PM
scotts300's Avatar
scotts300
I have 19x9 fronts with a 245/35/19 tire. There is plenty of room. I used to run a 275/35 front as well.
Old Apr 30, 2007 | 12:26 PM
Tubbs's Avatar
Tubbs
I hear understeer is murder.
Old Apr 30, 2007 | 12:27 PM
dkmesa350z's Avatar
dkmesa350z
****ing newb..get at least 245, 255/35 would be the best
Old Apr 30, 2007 | 12:29 PM
ARLETOS 350Z
Yo,i already running 235/35/19 front and 265/35/19 rear.I am planning if the 275/35/19 in rear can run the vdc safely.
Old Apr 30, 2007 | 12:33 PM
Tubbs's Avatar
Tubbs
VDC will be fine, but why do you think wider tires on the front are bad??? I'm confuzzled.
Old Apr 30, 2007 | 12:37 PM
ARLETOS 350Z
wide 19wheels+tyres on frond is always bad for road racing either track racing.
Old Apr 30, 2007 | 12:39 PM
Tubbs's Avatar
Tubbs
You're actually telling me that wide front tires will make you slower on a road course?
Old Apr 30, 2007 | 12:45 PM
scotts300's Avatar
scotts300
You'll be slower from the larger 19" wheel diameter versus the increased contact patch of "slowing" you down. I run 275s all around for road course and autox, both, as do many other members. There is a compromise for size vs weight, but I believe we're far away from that in this case. If you put a 395/30/20 on the front of your everyday Honda Civic, it would, in fact, be slower because it wouldn't be faster from the added width, but would be much slower because of the increase in rotational inertia of it.
Old Apr 30, 2007 | 12:57 PM
ARLETOS 350Z
So i can buy 275/35/ and run my old 235 with no problem to the vdc.Am i clear?
Old Apr 30, 2007 | 01:39 PM
JETPILOT's Avatar
JETPILOT
No one runs this combo because the tire sizes are incorrect. Your on your own with this one. Good luck!!! Let us know what you find out. People are trying to offer advice I suggest you take it.
235/35???? That's really really wrong.
JET
