Tire Install - TPS Problem
Old May 9, 2007 | 09:07 AM
KPierson's Avatar
KPierson
https://my350z.com/forum/wheels-and-tires/270378-my-tps-sensor-reprogrammed-itself.html
Check out post #2 there, kind of funny and relevent to this.
Old May 9, 2007 | 11:19 AM
Takhteh's Avatar
Takhteh
Originally Posted by KPierson
It sucks I have directional tires, if not I would swap them tonight just to see what happens!
"Directional" tires should not matter unless you are taking the actual tire off of the rim and giving it a "180" before putting it back on the wheel. If you take off the two rear wheels and put them on the reverse sides of the vehicle, the tread will be pointed in the same direction, and would be fine (not TPS, tho).. just FYI
Old May 9, 2007 | 12:47 PM
z-u-later's Avatar
z-u-later
That's not a problem . . . you can just drive in REVERSE and the tires will be fine.
Old May 9, 2007 | 12:50 PM
KPierson's Avatar
KPierson
To swap the tires left to right you will be turning them 180 degrees, thus making them operate backwards. I guess that as long as I don't drive the car too hard it shouldn't be an issue.
Actually, now that I think about it, I am having drag radials put on in a few weeks. I will have them swap sides when they are installed.
liqalu04
Jan 2, 2022 12:58 PM
Workshop12
Mar 23, 2020 01:45 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
RiujinZero
Sep 25, 2015 01:19 PM
