BBK = Worthless Spare
For those of you who have upgraded your brakes - are you just throwing caution to the wind and not worrying about a spare that fits over your new calipers?
I'm curious about this because I'll be traveling out of the state with my Z (track days!) and I no longer have a spare that will fit my after market Brembos. I've searched for spares at local and national salvage shops without any luck. The dealer can order the wheel without the tire for $222, but that seems expensive to me, especially after I buy the tire and have it mounted and balanced.
Any thoughts about where I might find a spare that will fit over my Brembos in a time-of-need? How about other car makes and models that use the same size spare (no idea what that size is or if it's universal).
Joel
Joel
Joel
Joel
Joel
Joel
Also carry a leatherman and a tire plug kit.
Mike
Originally Posted by Kolia
Put the spare on the rear axle of the car.
Use your imagination if you've blown a front tire...
thats going to look funny... right front side with 8" rims... rear with 9" rims... left side with 9" rims up front and donut on the back
Originally Posted by doug
with staggered rims?
Do you have any thing that match that ?!?
Originally Posted by gunslinger
A lot of cars (suprising how many) now come with the foam aerosal version of fix-a-flat and a compressor instead of a spare. You can get a compressor and f-a-f at pep boys or autozone for under $30 buck. It also save weight....
Mike
Mike
Joel, since I put my stereo amp and CarPC setup where the spare used to be, I have driven without a spare, only roadside assistance through my insurance, and a can of fix a flat. This includes 2 years and a trip across the country with no problems so far.
When I have my previous Z32, I had a similiar setup, with no spare, and this was 5 years, and 4 cross country trips. Had to use the can of fix a flat once, and that was not a problem.
Dave
Dave
It will kill the TPM if you inject it thru it. Not really a great idea
Plus, you should go for the tire plug first. This should cover most situations and is very easy to do. A tire plug tool kit is ~5 bucks at autozone. Get a decent pair of needle nose too.
If you shread a tire, you're sol, then I hope you have AAA.
Mike
Do you still have your stock rims? I bring one stock wheel with me to the track since its a pretty long drive, it fits right where the donut used to go. Other times, i just take the risk of having to call a tow truck.
Edit: this is assuming you are running on aftermarket wheels.
I'll look into the spacer idea. I have plugs too - just need a compressor. As someone mentioned above, that should be sufficient unless I tear a side wall or have some other massive tire malfunction.
Joel
Yeah, I do have after market rims and my stockers are just sitting in the garage. But with the staggered wheels, how would that work? If I put a front stocker on the back, won't it pull the car in all sorts of different directions? I realize the spare isn't the same size either, but with such a small contact patch, I assume it's not a big deal.
Joel
Joel
The car won't care is its riding on 4 different wheel sizes. Drive slow like you're supposed to and you'll be fine...
Or waste time and money for a problem you already have a solution for...
