Will TPM work with 03 touring Z
Old May 11, 2007 | 03:03 AM
will56's Avatar
will56
Default Will TPM work with 03 touring Z
I am purchasing stock rims off another member and they include the TPM. Will they work with my Z 03 Touring? I have done a searches but not sure i got the answer i was looking for from them. If anyone could help me with this question that would be great.
thanks
Will
Old May 11, 2007 | 03:14 AM
Yes. Most likely you will have to take the Z to the dealer so he can set-up the system electronically.
Old May 11, 2007 | 04:11 AM
DavesZ#3's Avatar
DavesZ#3
If it's an AT Touring that came with 17" wheels, then no, you don't have the TPMS. When you scroll through the multi-display (speed, temperature, timer, etc.), do you see the tire pressure display?
Old May 11, 2007 | 04:14 AM
will56's Avatar
will56
It is the AT 03. I am not near the car to check but that is disappointing. thank you for your imput
Old May 11, 2007 | 04:51 AM
Sorry. I assumed that the Z was set-up for TPMS.
Old May 11, 2007 | 08:27 AM
HitLines's Avatar
HitLines
Here is a pic of what it would look like:
Old May 12, 2007 | 07:05 AM
nicholasm617's Avatar
nicholasm617
my cars an 03 touring 6-spd. it shows just dash lines when i scroll through the display and see tire pressures, the car has aftermarket rims w/out sensors.
i asked my local dealer if i bought the sensors would they be able to pair it with the system and make it work, they said NO its not possible. i dont get it.
Old May 12, 2007 | 07:37 AM
Originally Posted by nicholasm617
i dont get it.
Neither do I.
Old May 12, 2007 | 07:48 AM
ANXIOUZ's Avatar
ANXIOUZ
Call another dealer. This is the first time I've heard one flat out deny they can't do it. For trims that have the tire pressure in the display, I was 99% sure you could take any Z TPS set and have them mapped up to the car so that the display works.
I'm in the same situation. I have aftermarket rims w/out the TPS. My display just shows dashes (F: --, R: --). I check my pressure regularly by hand though so I haven't bothered getting sensors. Although I think I would like that....
Old May 12, 2007 | 08:14 AM
DavesZ#3's Avatar
DavesZ#3
Yes, find another dealer. That one's obviously an idiot.
You can save a lot of $$ by buying a set here in the Marketplace, you'll pay less for all 4 than the dealer would charge for one. Get them mounted in the wheels then go to the dealer and tell them you need the sensors re-calibrated to the car's ECU. If they give you crap, tell them to look around page WT-16 of the factory service manual for the procedure. It should take them less than 30 minutes to do it and they don't need to touch anything on the car.
Old May 12, 2007 | 09:27 AM
nicholasm617
wait, what do they have to do to calibrate them exactly?
if its something you can do without special nissan diagnostic/programming software ill do it.... i know at work when we do those on bmw's if you replace a sensor it just reads it, no calibration or anything nescessary.
have a copy of page wt-16?
Old May 12, 2007 | 10:36 AM
DavesZ#3's Avatar
DavesZ#3
What they are doing is activating each sensor with a special "tool" then using the Consult system, telling the computer to recognize the unique ID of the sensor for a particular wheel position (FL, FR, RL, RR).
Old Jun 25, 2007 | 08:16 PM
dj20009's Avatar
dj20009
a z without tpms actually has it built in to the module. They are actually the same for all at least in 03. They even have the rev limiter in a automatic it just dosent go anywhere. Now weather or not they can change it from factory tuning I dont know.
_bit
Oct 2, 2015 07:49 AM
