Another one of those "will this rub?" thread :(
Old May 26, 2007 | 10:22 PM
ssgohan434's Avatar
ssgohan434
Default Another one of those "will this rub?" thread :(
Got the SSR SP1 Professors in 19x8.5 and 19x10 with +37 offsets all around. The fronts are wrapped in 255 and the rears in 285. I was thinking about getting some spacers but can't decide what size. I have a chance to get a set of 15mm and 20mm spacers for cheap. Would an effective +17 in the front with an effective +22 in the rear after spacers be fine/no rubbing? (using the 20mm spacer upfront and 15mm spacer in the rear).
Thanks!
forgot to mention that I'll be doing a mild lowering this summer with Tein S-techs.
See below at posts 10 and 11 for pics
Old May 26, 2007 | 10:24 PM
BhashaZ's Avatar
BhashaZ
You should be okay all around.
Old May 26, 2007 | 10:41 PM
ssgohan434's Avatar
ssgohan434
^ I was thinking it would be ok, but I'm just worried about the 285 and 255mm tires
Old May 26, 2007 | 10:44 PM
05-Z's Avatar
05-Z
Depends on how low, and tires too, but you should be ok.
Old May 26, 2007 | 11:15 PM
blaukal's Avatar
blaukal
I'm at 10.5 +23 in the back with 285/35s and an S-Tune drop, and I just barely rub under extreme conditions. So you'll be close -- probably is going to depend on how far you go on the drop. Easy solution: roll/cut.
Old May 26, 2007 | 11:25 PM
ssgohan434's Avatar
ssgohan434
According to this calculator : http://www.1010tires.com/WheelOffsetCalculator.asp
the outer position of my rear wheels with the effective 22mm offset should be 5mm more inside the wheel wells. So the rears might be fine . Now how about the fronts?
Old May 27, 2007 | 02:14 PM
redlude97's Avatar
redlude97
I have 19x8.5+20 ssr sp1's on the front, and they are tucked. I'm planning on adding a 15-20mm spacer so +17 is nothing
Old May 27, 2007 | 02:15 PM
plumpzz's Avatar
plumpzz
if you rub ur gonna rub suspension components. I think you'll be fine.
Old Jun 29, 2007 | 09:16 PM
ssgohan434's Avatar
ssgohan434
*bump and update*
The rears are barely rubbing the fender, but the bad thing is that the springs have just been installed and haven't been able to "settle" in yet. So im worried that they will eventually rub even more once it does settle. Pics soon.
Old Jun 29, 2007 | 09:40 PM
ssgohan434's Avatar
ssgohan434
General pics of the updated setup, Tein Stechs freshly installed.
Attached Thumbnails Another one of those "will this rub?" thread :(-dsc00245.jpg   Another one of those "will this rub?" thread :(-dsc00246.jpg   Another one of those "will this rub?" thread :(-dsc00247.jpg   Another one of those "will this rub?" thread :(-dsc00248.jpg   Another one of those "will this rub?" thread :(-dsc00249.jpg
Old Jun 29, 2007 | 09:42 PM
ssgohan434's Avatar
ssgohan434
Pics of the rubbage on the rear tires and a couple pics from a distance. Let me know what you think. I can't decide if I like the rear tires that far out. The rears are 37+ offset 19x10 with 285/35/19 BFG KDWs. They have a 15mm spacer making them 22+ offset. Opinions valued, thanks!
Attached Thumbnails Another one of those "will this rub?" thread :(-dsc00250.jpg   Another one of those "will this rub?" thread :(-dsc00251.jpg   Another one of those "will this rub?" thread :(-dsc00252.jpg   Another one of those "will this rub?" thread :(-dsc00255.jpg   Another one of those "will this rub?" thread :(-dsc00259.jpg
Old Jul 3, 2007 | 12:11 AM
ssgohan434's Avatar
ssgohan434
^ bump, no feedback? :-(
Old Jul 3, 2007 | 12:18 AM
redlude97's Avatar
redlude97
looks fine to me, roll your fenders and you'll be good to go
Old Jul 3, 2007 | 12:52 AM
JETPILOT's Avatar
JETPILOT
I have 10" +25's with a 295/30 and I don't rub with a 1.25" drop. The lips will have to be rolled.
JET
hulkout
Apr 28, 2017 09:00 PM
Tochigi_236
Sep 27, 2015 03:40 PM
