25mm Spacers on all 4 wheels
May 28, 2007 | 12:10 PM
Would that be too much for a 2007 350z with stock wheels
May 28, 2007 | 12:21 PM
no but i would do 20 in front and 25 in rear.
May 28, 2007 | 02:18 PM
why would you not do 25 and 25 ? Whats the reason for the difference ?
May 28, 2007 | 02:19 PM
idk...maybe you might rub in the front? but i think ive seen only one person on this forum thats done 25 all around on 06+ and it was fine iir
May 28, 2007 | 04:46 PM
What benefit to spacing the stockers?
May 28, 2007 | 05:06 PM
Quote:
Makes the wheels flush with the fenders, for looks basically.
May 28, 2007 | 06:44 PM
Quote:
Do a search and you'll see pics of 20mm front & 25mm rear setup. If you decide in the future to mount same size tires on all four corners, your tires will still out in front if you install 25mm spacers.
May 28, 2007 | 07:23 PM
ok, as long as I always mount stock rubber to the car 25&25 should be fine then ?
May 28, 2007 | 07:40 PM
yes it will be fine.
I think a reason why people go 20/25 is because it looks more of a rwd staggered look since the rear is pushed out more.
i, myself, would put 20/25.
Obadabot
Jun 18, 2023 11:31 PM
