Volk GT-7 offset
Old Jun 7, 2007 | 08:37 PM
hkman78's Avatar
hkman78
Default Volk GT-7 offset
What is a good offset for 19x9.5 and 19x10.5 GT-7 wheels for non-brembo Z?
Old Jun 7, 2007 | 09:42 PM
nooooorb's Avatar
nooooorb
Originally Posted by hkman78
What is the offset of the gt-7?
Your question from a different thread...
A good offset for any wheel would be +18 to +25. In my case, I have +23F and +19R. Hope that helps.
Old Jun 7, 2007 | 09:50 PM
hkman78's Avatar
hkman78
ic, do you have 8.5/9.5 setup or 9.5/10.5?
I am thinking about 27 front, 24 back for a 9.5/10.5 setup. I guess thats should be ok right?
Old Jun 8, 2007 | 08:05 AM
Volk350Z's Avatar
Volk350Z
Master
There's 2 different offset setup for 9.5/10.5
NonAggressive 9.5 +30 & 10.5 +24
Aggressive 9.5 +17 & 10.5 +15
both will also clear BBK front kit later...
Old Jun 8, 2007 | 08:29 AM
hkman78's Avatar
hkman78
Hey Brian, thanks for the response.
I was looking into the fitment chart from Mackin fot gt-7, the aggressive offset from your recommendation would give me the same size lip as the +27 front and +24 back. Can I go with that setup since the offset is less aggressive but give me the same size lip?
Old Jun 8, 2007 | 11:01 AM
Volk350Z's Avatar
Volk350Z
Master
I personally wouldn't do +27 front, cause
A) it will not clear any BBk or OEM Brembo
B) alot harder to sell later if you decide to sell them,
C) Rays make more +17 or +30 so it would be faster to get..
Old Jun 8, 2007 | 11:20 AM
hkman78's Avatar
hkman78
Hey Brian,
Good point about the selling. I probably have to wait when I decide to order it anyway. I have been looking for the regular gold for the Gt-7, but not too many people have it.
Is there any rubbing issue with +17 in the front? I probably try to get +24 in the rear to avoid any rubbing problem.
Old Jun 9, 2007 | 02:38 PM
davidf's Avatar
davidf
I had 19x8.5+23 fronts 19x10.5 +24 rears. +24 rear gives you a true 4" lip and easily clears brembos.
Old Jun 9, 2007 | 02:39 PM
davidf's Avatar
davidf
I ran 275/35/19 rears with zero rubbing on hotchkis.
Old Jun 9, 2007 | 10:50 PM
XM 1's Avatar
^^ did u roll rear fenders?
Old Jun 10, 2007 | 12:09 AM
InZomniac's Avatar
InZomniac
I am running 20X9.5 with a 15 offset and a slight fender roll if that helps. My next set will be 10.5 and 10 offset with more roll if that helps.
Stevo Z
Oct 3, 2015 09:14 PM
