Tire Width Questions
Old Jun 17, 2007 | 07:38 PM
SunsetSunrise's Avatar
SunsetSunrise
Question Tire Width Questions
I know I should be searching 1st, and i did, but could not find the answer.
So here is the question:
Right now i have 18x8.5 front & 18x9.5 rear.
245/45/18 fronts & 275/40/18 rear
I would like to go wider on the rear
How wide can I go?
295/35/18?
Thanx guys.
Old Jun 17, 2007 | 07:55 PM
dkmesa350z's Avatar
dkmesa350z
You could do that. I'd do 255/40f 275/40r personally but you can fit 295/35 on a 9.5" wheel but you will have to get a shorter front tire (ie 245/40) to avoid confusing vdc/tcs
Old Jun 17, 2007 | 08:04 PM
I do not recommend a 295 mm tire on a 9.5 inch wheel. What is interesting about this forum is that you will get any answer that you want.
Old Jun 17, 2007 | 08:09 PM
Fluid1's Avatar
Fluid1
Why do you say this David? I run very hard on a 255/40/17 on a 7.5" wide rim. I would guess that I could even fit a 275 on there.
I do agree with the part about being able to get any answer you're looking for.
To the OP: If you go wider in the back, go wider in the front as well. Use a tire calculator and make sure that you are increasing both of the contact patches. The more imbalance to the rear you have, the more understeer you'll get.
Old Jun 18, 2007 | 02:13 AM
redlude97's Avatar
redlude97
wow, my 235/50/17 on a 17x7 already looks bulging, I'd hate to see a 275 on a 7.5
Old Jun 18, 2007 | 02:53 AM
WA2GOOD's Avatar
WA2GOOD
We have ran up to a 285/30/18 on a 18x8.5" wheel up front and a 315/30/18 on a 18x9.5" wheel on the rear. I use this tire combination all the time for years, no problems at all. This is assumeing that your ride hight and wheel offsets are in check. I wouldn't recomend anything over these sizes, but you can go "up to" these sizes on your wheels with no problems.
Old Jun 18, 2007 | 03:24 AM
lowrider's Avatar
lowrider
Just a question for you. Why are you not running a staggered height setup? You're OD is the same front and rear.
Lou
Old Jun 18, 2007 | 09:37 AM
SunsetSunrise
so would 245/45/18 f
and 305/35/18 r
would be alright?
is that too much difference in width?
Old Jun 18, 2007 | 09:44 AM
WA2GOOD's Avatar
WA2GOOD
and 305/35/18 r
would be alright?
I am pretty sure it would "work", but it is not ideal IMO. Might be just OK on a non lowered car though, I guess.
Old Jun 18, 2007 | 09:45 AM
1nate7's Avatar
1nate7
I'd do 275/35 front, 295/35 rear for max width. I saw that combo on a set of 8.5/9.5 Rotas this weekend and it looked pretty good although there was a little sidewall bulge. 245 front, 305 rear = severe understeer.
Old Jun 18, 2007 | 11:49 AM
SunsetSunrise
so may be i should go with 285/40 rear while 245/45 front?
Old Jun 18, 2007 | 05:52 PM
WA2GOOD's Avatar
WA2GOOD
Not a big fan of a 40 or 45 series tires
Old Jun 18, 2007 | 08:49 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Look at the tire application guild from the manufacture. Most tables will tell you that 285s are the most you should run on a 9.5" wheel.
Old Jun 19, 2007 | 07:22 AM
lowrider's Avatar
lowrider
Nobody posting to this thread seems to give a darn as to what you should or should not run on these wheels according to manufacturers recommendations, or cares about the stagger
Lou
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
