Vibrating Problem
Old Jun 18, 2007 | 02:43 PM
FreemeZ's Avatar
FreemeZ
Default Vibrating Problem
When I drive faster than 75mph my car vibrates violently in the front. This is really bothering me because it makes the car feel really unstable when I drive fast, plus it's very uncomfortable when driving long distances (longer than 20 mins). I looked in carfax for my car and saw that the previous owner had work done on the suspension. I was wondering if anyone else had the same problem, or if it's just my car. I've had my car for about 8 months now, and I always just thought it was normal until it started getting worse.
Old Jun 18, 2007 | 02:44 PM
Richy350Z's Avatar
Richy350Z
It's not normal. Maybe one of the wheels was hit against a curve and bent the rim a little? That could be one reason, but you need to get it checked out
Old Jun 18, 2007 | 02:45 PM
Richy350Z's Avatar
Richy350Z
Forgot to add:
Also, don't be like the RX7 that forgot to tighten up his lugs!
Old Jun 18, 2007 | 03:22 PM
jimmyloose's Avatar
jimmyloose
get your wheels balanced.
Old Jun 18, 2007 | 03:32 PM
DavesZ#3's Avatar
DavesZ#3
1) Wheels out of balance
2) Out-of-round tire (bulge, egg, tread separation, etc.)
3) Wheel bent
Old Jun 18, 2007 | 03:47 PM
NightRida's Avatar
NightRida
4)suspension is ****ered!
Peace!
Old Jun 18, 2007 | 04:17 PM
spf4000's Avatar
spf4000
And if you have a lot of negative camber on the front, it can make your car feel dodgy and nervous going straight as well, although the Z doesn't allow much adjustment in that area without aftermarket parts.
Old Jun 18, 2007 | 04:24 PM
Nism0_RoLLa's Avatar
Nism0_RoLLa
Try balancing all 4 wheels and see what happens, and if the rim is bend, the ballancing mechine will tell you. If its not that, it might be your suspension or any of the tires, because if the tires have a little bump on them, you will feel the car viberating.
Old Jun 18, 2007 | 05:07 PM
DavesZ#3's Avatar
DavesZ#3
How old is the car and how much mileage? Unless it's old and high mileage, I doubt it's the suspension unless it was damaged and improperly repaired.
Old Jun 18, 2007 | 05:25 PM
redmansioner's Avatar
redmansioner
Check your nissan knock sensors aside from the suspension.It could not been functioning at all.And about those suspension,I want to know how old is your car.
Old Jun 18, 2007 | 09:05 PM
FreemeZ's Avatar
FreemeZ
My car is a 2003 with 42,000 miles. I bought it used last year with 35,000 miles on it. I am thinking about taking it to a track for a track day, but i'm a little uneasy about it cause of the vibrating. I will take it to the dealership this weekend. It's still under warranty so hopefully there is something that they can do. But, what if it has something to do with structural damage. For example, what if the persom before me hit something and never fully got it repaired. What could I do about that?
Old Jun 18, 2007 | 09:53 PM
Thanh386's Avatar
Thanh386
I am having a similar problem. I believe it's coming from teh front passenger side. If you figure something out tell me. I am getting the car aligned tomr, cause i've tried everything else.
Old Jun 18, 2007 | 10:06 PM
kylekyle350z's Avatar
kylekyle350z
maybe your strut bar is touching your Plenum.
Had the same problem..
Old Jun 18, 2007 | 10:21 PM
Thanh386's Avatar
Thanh386
it's not a steady vibration. At around 75mph (only when cruising, doesn't happen when accel.) it vibrates stops and vibrates again.
Old Jun 19, 2007 | 07:35 AM
rcdash's Avatar
rcdash
does it become more pronounced turning, like when changing lanes? can you hear it? might be a wheel bearing... if you lift the car (jack stands or whatever), grab each wheel and see if there is any play on one side vs. the other. if you can jiggle the wheel then the wheel bearing needs to be replaced. an alignment won't fix this issue and my dealer couldn't figure it out, but a local suspension expert diagnosed it in 5 mins.
Old Jul 21, 2007 | 08:48 AM
solarinsocal's Avatar
solarinsocal
Dude, you're tires are feathered. Go check them and then rotate them.
Old Jul 21, 2007 | 04:56 PM
tmak26b's Avatar
tmak26b
warp rotors can cause the wheel to shake too, dont forget that
Old Jul 21, 2007 | 06:06 PM
Delako's Avatar
Delako
My Old stealth used to shake terribly at higher speeds. Made driving above 70 unbearable.Took like 5 trips to the dealer to figure it out. Something about the front axle bearing locking up and not letting it flex in the right way..so instead it shimmied from left to right. Replaced the front axle and it was lke buttah thereafter
Old Aug 5, 2007 | 10:01 AM
zodiac's Avatar
zodiac
I have the EXACT same problem...
Did you get this fixed? If so, what was the issue.
Any info would be GREATLY appreciated.
Thanks man,
Zod
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
