265/35 18" or 255/40 18"
Old May 5, 2003 | 08:39 PM
webcarconnection's Avatar
webcarconnection
Default 265/35 18" or 255/40 18"
I don't know if anyone ask the same question but, can I put 265/35 tires in my 18x8 Performance/Touring wheels or the 255/40?
Thanks!
Old May 6, 2003 | 02:56 AM
Pedal Pusher's Avatar
Pedal Pusher
Sounds like you are pushing the limits. Check your owners manual to learn the width of your wheels. I think they are 8". Then go to tirerack.com and you will be able to see if your tire selection will fit the wheels. Good luck!
Old May 6, 2003 | 04:54 AM
John's Avatar
John
245 is the widest that can fit on a 8" rim. 255 = 8.5", 265 = 9"
Old May 6, 2003 | 09:35 AM
ares's Avatar
ares
Veteran
more or less yes, kinda confusing but there are ~24mm per inch. while obviously 245mm>10 inches, it will fiton a 8" rim, Ive never understood why or how, but it does. however you cant go any wider, if you add 10mm your adding ~half an inch, and can thus fit it on a half inch wider tire.
there is some leeway, Ive seen 255 on the stock 8" tires(the bow out a bit on the sidewall, but it can be done), but then again consider that 225 will fit on 8" tires, as thats whats used on the front. 265 would be overdoing it, 275s are standard for 9.5" rims.
Old May 6, 2003 | 04:09 PM
webcarconnection
Thanks!
jb0
East Canada
Jul 30, 2007 10:55 AM
DavesZ#3
Dec 18, 2006 08:19 AM
mikedZ33
Dec 25, 2005 12:48 AM
joust75
Mar 15, 2004 07:06 PM
