Do 11.5 wide in the rear fit?
Old Jul 11, 2007 | 06:39 PM
Zexy's Avatar
Zexy
Default Do 11.5 wide in the rear fit?
I am debating to but some wheels for sale but i am wondering if 11.5 wide in the rear fit with a conservative (not aggressive) offset to fit wide tires.
Does anybody KNOW if i will run into rubbing issues with the strut in the rear or any other component?
Old Jul 11, 2007 | 07:57 PM
SmokyTyrz's Avatar
SmokyTyrz
Don't think it will fit without modification.
Old Jul 11, 2007 | 07:59 PM
Ruthless18x's Avatar
Ruthless18x
Darren with Intense is running 11s. I'm not sure about 11.5s.
Old Jul 11, 2007 | 08:19 PM
OffsetZ33's Avatar
OffsetZ33
There used to be a sticky about the possibility of a 11.5 Volk I think - gauging interest, but I dont know what happened to it. It listed some offsets of their possibilities I think to be able to run a wide tire.
Old Jul 11, 2007 | 08:20 PM
OffsetZ33's Avatar
OffsetZ33
Here it is:
https://my350z.com/forum/wheels-and-tires/229610-11-5-wide-wheel-any-takers.html
Old Jul 11, 2007 | 11:13 PM
redlude97's Avatar
redlude97
A guy on g35driver was running 12's in the rear, so an 11.5 should fit with the right offset
Old Jul 12, 2007 | 08:44 AM
roncfpz's Avatar
roncfpz
Hey bro, i think it will work with the perfect offset. I just went to an 11" with +32 offset and there is still some room. What size tire are you planning?
Old Jul 12, 2007 | 02:01 PM
Zexy's Avatar
Zexy
Maybe a 315 drag radial Ron..
BTW: The new wheels are looking pretty stealthy!
redlude, can you give me the link?
Old Jul 12, 2007 | 02:18 PM
roncfpz's Avatar
roncfpz
Thanks!
I just checked my clearances and it will real tight. I have maybe 4mm (or less) of clearance from the shock body and the outer is pretty flush with the fender. Then again I'm running 20s so an 18 would have the outside diameter of the rim at a lower point on the shock body which leans towards the wheels at the top.
Old Jul 12, 2007 | 04:16 PM
redlude97's Avatar
redlude97
http://g35driver.com/forums/showthread.php?t=158751
The guy is only running a 285 on them though
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
