Calling all users of 5mm spacers
Old Jul 31, 2007 | 08:17 AM
djParis's Avatar
djParis
Retired Racer
Default Calling all users of 5mm spacers
I've had no luck selling my 355mm StopTechs, so I've decided to bite the bullet and buy some 5mm spacers to get them to clear my Work Meisters. To those running 5mm spacers how is the ride quality, any shimmy with the wheels etc? Also how will these work with my hubcentric rings from my Works. I'm very against the use of spacers and want to become as educated as I can before I make the plunge. What are the best spacers I can buy?
Old Jul 31, 2007 | 09:22 AM
z-u-later's Avatar
z-u-later
You can educate yourself by using the SEARCH function. There are dozens of threads already in this forum regarding the benefits of using spacers, in addition to the list of spacer manufacturers.
Old Jul 31, 2007 | 10:56 AM
Triple8Sol's Avatar
Triple8Sol
Werd. Look into H&R and Eibach. Both are hubcentric.
Old Jul 31, 2007 | 11:51 AM
noodleman's Avatar
noodleman
i don't think there are such things as 5mm hubcentric spacers...since they dont' really cover up the hub by themselves...
Old Jul 31, 2007 | 03:58 PM
taurran's Avatar
taurran
Uh, yes there is.
Old Jul 31, 2007 | 04:02 PM
OffsetZ33's Avatar
OffsetZ33
Yeah a spacer of any size can be hubcentric. My 3mm spacers were made hubcentric.
-although I see what you are thinking - they do not have the extra lip that would be hubcentric to the wheel - I still use my rings in combination with my spacers.
Old Aug 4, 2007 | 10:52 PM
wamuboy714's Avatar
wamuboy714
I'm running a 5mm spacer and I also changed out the studs also for proper fitment. As an owner of an aftermarket retail shop, all 5mm hubcentric spacers are identical, so why not pay for the least expensive one. I'm using the Ichiba 5mm spacer through optionimports.com. You can order it there and save yourself some money. I've had no problems with the spacers and the ride quality.
Old Aug 4, 2007 | 10:54 PM
mr. sparco's Avatar
mr. sparco
I ran 5mm spacers on stock lugs for a few weeks and then took them off. Not worth the risk IMO unless you have extended studs. Didn't have any problems with the spacers when they were on though.
Old Aug 5, 2007 | 06:30 AM
OffsetZ33's Avatar
OffsetZ33
General rule of thumb is that you want 7 full turns of the lugnut to tight. If you are getting less than this you should run longer studs.
Old Aug 7, 2007 | 07:23 AM
import_theory's Avatar
import_theory
there's a guy on my board making custom fitted spacers for pretty cheap
im getting two for the rear to clear the wider wheels
just let me know hoe
Old Aug 7, 2007 | 12:12 PM
DMK's Avatar
DMK
What brand of 3mm spacers do you have? Hubcentric spacers have to have a protruding lip, correct?
Old Aug 7, 2007 | 12:28 PM
Motormouth's Avatar
Motormouth
if you aren't running a spacer with built in studs (h&r style) test how much you can thread the lug nut on. as someone said 6 or 7 turns is the standard. if you get less then that, get longer studs.
I have 15mil spacers on the rear of my car, and I have never noticed any shimmy from them or any negatives... they do have different torque specifications iirc that require slightly less ftlbs then normal... but i could be wrong. someone mentioned before they snapped thier lugs off cause they made the spacer to the hub too tight.
Old Aug 7, 2007 | 04:04 PM
OffsetZ33's Avatar
OffsetZ33
Mine are custom made, but hubcentric means that they are designed to fit the hub and not necessarily just the lug pattern. Some larger spacers have a lip that can be hubcentric to the wheel as well (and not just to the car). Mine as still small enough that I run the normal hubcentric rings still.
Old Aug 7, 2007 | 04:11 PM
DMK's Avatar
DMK
Ya, don't be this guy.
http://www.youtube.com/watch?v=OQlxPZznrFo
JK.
Old Aug 7, 2007 | 04:20 PM
LANshark's Avatar
LANshark
I have 25mm adapters (spacers with their own studs) on my Tiburon and have had no problems whatever except for a very slight rubbing in the rear which I fixed by grinding away about 1/4 inch of the fender lip.
350Z_Al
Oct 29, 2020 07:44 PM
