going from a 45 stock to a 40?
Old Aug 21, 2007 | 09:58 AM
Get_Zwole's Avatar
Get_Zwole
Default going from a 45 stock to a 40?
hey guys got a hole in my sidewall in my passenger front tire. Im gonna replace the fronts for now with potenza re01-r ive heard great reviews. Theres a 30 dollar per tire difference on tirerack.com between the 45's and 40's. My question will it hurt anything to get the 40's since they are cheaper and keep the 45's on the back? thanks sorry im dumb with tires and wheels.
Old Aug 21, 2007 | 10:04 AM
redlude97's Avatar
redlude97
if you want to go down to a 40 series tire in the front, then bump with width up to 245 to compensate for the height stagger inherent in the stock setup.
Old Aug 21, 2007 | 10:06 AM
Get_Zwole's Avatar
Get_Zwole
i wanted to keep the stock stagger since i wont be switching rims either ill be sticking with the stocks. So you think i should get the 45's then id really rather stay the same size.
Old Aug 21, 2007 | 10:29 AM
Alberto's Avatar
Alberto
Cranky FI Owner
It will look silly-wheel gap will increase. If I were you Id run 245/40/265/40 on stockers, but your worried about $30 diff so you likely wont do that...
Old Aug 21, 2007 | 10:38 AM
Get_Zwole's Avatar
Get_Zwole
well i was asking opinions and im not completely worried about money, but when you ahve the same exact tire but 5mm taller and 30 bucks more i would think any normal person that watches their money would rather buy the cheaper tire, if it would work properly. I think im gonna go with the 245's after all. I dont have the money for the rears yet. So ill be running 245's all around.
Old Aug 21, 2007 | 10:39 AM
Get_Zwole's Avatar
Get_Zwole
thanks for the help btw guys
Old Aug 21, 2007 | 10:44 AM
Get_Zwole's Avatar
Get_Zwole
Ok sorry one more ? Tirerack is where im getting them, they have 245/40/18's but, when i get the rears the only sidewall they have in a 265 is a 35. It will be a couple weeks before i can get the rears, but i need the fronts asap because the hole and i have a 60 mile commute. What would you advise i do about the 35 in the rear?
Old Aug 21, 2007 | 10:47 AM
redlude97's Avatar
redlude97
Its more than 5mm, its almost a full inch shorter in diameter
Old Aug 21, 2007 | 10:48 AM
redlude97's Avatar
redlude97
go 255/45/18 in the rear instead
Old Aug 21, 2007 | 11:33 AM
Makes things simple for me.
What size is the front tire?
Rear?
Old Aug 21, 2007 | 12:19 PM
Get_Zwole's Avatar
Get_Zwole
i guess im going for a 245/40/18 or 245/45/18 up front, and now i wanna go 265/45 in rear, but they only have 35's in the rear. Man this is confusing. Even the 255's all they have is 35 on the sidewall. I guess not many people run the re01-r's in staggered setup?
Old Aug 21, 2007 | 12:45 PM
kennyl5123's Avatar
kennyl5123
get ADVAN Neova AD07 and put 235/40/18 front and 255/40/18 rear. I had this setup before and it's better than now I have 240/40/18 and 275/40/18. Save gas and easier control at high speed.
Old Aug 21, 2007 | 12:55 PM
Get_Zwole's Avatar
Get_Zwole
Ive pretty much decided on the potenzas rated a little better then the advans in just about everything including ride which i like too. Plus the advans are like 80 bucks more on tirerack. im bout to say screw it and just order 4 245/40/18's and get on with it.
Old Aug 21, 2007 | 03:34 PM
Get_Zwole's Avatar
Get_Zwole
alright im thinking of this 245/40/18 in the front and 265/35/18 in the rear will there be any complications with that? Thats all i can find in the tires that i really want.
Old Aug 21, 2007 | 03:35 PM
Alberto's Avatar
Alberto
Cranky FI Owner
265/35 is too small, look for 265/40
Old Aug 21, 2007 | 03:42 PM
Get_Zwole's Avatar
Get_Zwole
damnit lol thats the only size they offer in 265 in those potenzas
Old Aug 21, 2007 | 08:05 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Why not get some KDW 2's?
Old Aug 21, 2007 | 08:06 PM
Get_Zwole's Avatar
Get_Zwole
welp i just went with 245/40/18's for the front i just did a ton of research. One of the things i found out was 245's all around will help the car drive more neutral. yes i am new to sports cars lol only fast cars i drive usually are drag racing. I also heard that if you use a 40 up front and a 45 in back then vdc will still work fine. Hope this is true. In a few weeks ill be getting the same tires for the rears except 45's. Then adding sways and springs hopefully it will stick like glue .
Old Aug 21, 2007 | 08:07 PM
Get_Zwole's Avatar
Get_Zwole
ps thanks for the help once again guys. I didnt get flamed on this thread either starting to like it a bit more and more over here lol.
