will 265/35ZR18 tires fit on a 8.5" wide rim?
Old Aug 26, 2007 | 05:47 AM
calebmilla's Avatar
calebmilla
Default will 265/35ZR18 tires fit on a 8.5" wide rim?
I'm looking at getting 265/35ZR18 Kumho v700 tires and I need to know if they'll fit on a 8.5" wide rim? Thanks.
Old Aug 26, 2007 | 06:13 AM
Z04's Avatar
Z04
http://www.1010tires.com/TireSizeCal...?action=submit
Old Aug 26, 2007 | 07:53 AM
The NISMO wheel is 8.5 inches. What tire width does NISMO recommend?
Old Aug 26, 2007 | 07:56 AM
jjellyneck's Avatar
jjellyneck
245/40
Old Aug 26, 2007 | 11:41 AM
calebmilla's Avatar
calebmilla
Thank you everyone for the info. That is the best tire calculator I've seen, since it includes the wheel width range. That's just what I was looking for. Plus, I got some good info in a private message. Looks like I'll be able to use that tire!
Old Aug 26, 2007 | 09:59 PM
mthreat's Avatar
mthreat
I ran a BFG KD 265/35/18 on my 8.5-inch rim, the tire fit on the rim just fine, although 265 may be pushing it a bit (sidewall flex, etc). I did have some rubbing problems under high braking or turning load (or both), which ended up putting small cuts on my tires, causing them to blister prematurely on the sides. If you're turning/braking hard, keep an eye on them. Oh also I think my rim offsets were +.22 or something, and I should have probably been running +.26 or so - this 4mm might have prevented the rubbing.
Old Aug 27, 2007 | 09:06 AM
usmanasif's Avatar
usmanasif
Sidewall will be way too bulgy with a 265 on just an 8.5" wide wheel. Just because a tire fits doesn't mean you should run with it. It will look awkward.
Old Aug 27, 2007 | 09:15 AM
rkd350z's Avatar
rkd350z
check it out
Attached Thumbnails will 265/35ZR18 tires fit on a 8.5" wide rim?-sa503976.jpg   will 265/35ZR18 tires fit on a 8.5" wide rim?-sa503970.jpg
Old Aug 27, 2007 | 09:54 AM
redlude97's Avatar
redlude97
Originally Posted by rkd350z
check it out
ugg....do people never learn?
Old Aug 27, 2007 | 10:05 AM
twenzel's Avatar
twenzel
I had 265/35/18, on my 2003 track wheels. It was fine with minimal sidewall flex. I used in autoX events too and it was a great improvement over stock tire sizes.
Old Aug 27, 2007 | 10:07 AM
twenzel's Avatar
twenzel
check it out
That looks like a truck tire. You should have gone with 35 series profile.
Old Aug 27, 2007 | 10:11 AM
jimmyloose's Avatar
jimmyloose
Looks like it fits to me...
What it does to the sidewall is another topic entirely tho.
Old Aug 27, 2007 | 03:21 PM
calebmilla's Avatar
calebmilla
Thanks for the input guys. I'll be posting some pics as soon as I get the tires mounted. To address any rubbing issues that come up, I'll be playing around with some wheel spacers.
Old Aug 27, 2007 | 04:49 PM
That's the good thing about this forum. You can get any answer that you want.
Old Aug 30, 2007 | 03:09 PM
calebmilla's Avatar
calebmilla
They fit pretty good. They look like they're bowing in a little bit in the middle of the tire but hopefully not enough to cause any problems. There's no rubbing though. I'm using 5mm spacers but I don't think they would even rub without them.
will 265/35ZR18 tires fit on a 8.5" wide rim?-newtires-004.jpg
Old Aug 30, 2007 | 03:21 PM
RBlover69's Avatar
RBlover69
i have the GT wheels for the 07s 19s in the back with the 265/35/19s im thinking about going with the re50s but in 275...want a little wider. Any doubts with that
Old Aug 30, 2007 | 04:05 PM
RBlover69's Avatar
RBlover69
im actually thinking of going 275/35/19 bridgestone pole positions since they have such better reviews . but wonder how would they fit and look on my stock GT 07 wheels for the rear only....because i would be keeping the front tires re50a because they have tons of thread on them while the back as pole postions. What do ya think.
Old Aug 30, 2007 | 05:51 PM
phooka's Avatar
phooka
can you post any more pics of this setup? I have the 03-05 tracks and im running a 15mm spacer in the front and a 20mm in the rear.
Old Aug 31, 2007 | 03:29 PM
calebmilla's Avatar
calebmilla
If you have stock suspension you should be fine if you have the right offset. If you have it converted to a true coilover setup in the back and it's lowered you might have some rubbing depending on the offset you have.
Old Aug 31, 2007 | 03:35 PM
calebmilla's Avatar
calebmilla
No, I don't have any pix of it on the car if that's what you're asking, I just put the wheel on to check for any clearance issues, then put the stock wheel back on. The reason you're having to use such large spacers is probably because the stock track wheels have a much different offset than my wheels. Mine have a 32. What does the stock track wheel have for the front?
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
