Max tire size for 19x9.5
Old Aug 29, 2007 | 11:21 AM
pingrr's Avatar
pingrr
Default Max tire size for 19x9.5
I just bought a set of 19's for my car. The rear tire is 19 x 9.5 with an ofset of 20. What is the widest tire size I can fit on the car without rubbing. Will a rim with that offset fit a 285 or 295 without any rubbing issue?
Old Aug 29, 2007 | 11:43 AM
redlude97's Avatar
redlude97
285 is the widest safe width to go, without addressing offset and rubbing. 295 is outside of the safe manufacturer's specs for that width wheel
Old Aug 29, 2007 | 11:44 AM
1nate7's Avatar
1nate7
+1, a 285 shouldn't rub with that offset.
Old Aug 29, 2007 | 11:47 AM
dkmesa350z's Avatar
dkmesa350z
I would run a 285/35 but there is a slight chance it may rub. Are you lowered?
Old Aug 29, 2007 | 12:22 PM
pingrr's Avatar
pingrr
No I'm not lowerd. I want to go with 285's for a little wider look than 275's but I just was't sure if they would rub or not.
Old Aug 29, 2007 | 10:33 PM
350Zimo's Avatar
350Zimo
mines are 285 on a 9.5 , looks perfect, the sidewalls are not buldged out, you will be fine.
