wheel spacers..quick question
Old Aug 31, 2007 | 04:12 PM
mondi's Avatar
mondi
Default wheel spacers..quick question
been looking through the search
had talked to my friend about gettin wheel spacers...
don't know if he was wrong or not but he said when the screws or studs are seperated..u gotta do something with the stock studs and it becomes labor intensive
whereas u can just buy some with the studs already mounted...don't know if anyone can understand me but anyone know any brands thats just plug and play or all of them are like that
was thinkin about gettin the tc sportline..let me know..tryin to buy now thx
Old Aug 31, 2007 | 05:06 PM
The spacer goes between the hub and wheel. You need sufficient threads on the studs remaining so that you can safely attached the wheel with the lug nut.
Old Nov 15, 2007 | 02:19 PM
QM888's Avatar
QM888
Default Please help w/ Wheel spacer
I m looking for wheel spacer w/ 18 stock wheels. I heard Eibach pro have ones w/ studs build in ....all you need is put over stock studs. is this correct?
should i get 15mm for front and 20 mm for rear or 20 f and 25 r or 25 r..please advise.
i talked to performance niss and they charge 200 bucks for install them...they said they need to knock off the stock one...need to open the rotor to replace w/ longer studs...or something....is this right?
Old Nov 15, 2007 | 02:28 PM
noodleman's Avatar
noodleman
project kics spacers have studs built onto the spacer. That's what i'm using.
if they don't, you'll need to knock the stock studs out and replace them with new ones (which is labour intensive).
Old Nov 15, 2007 | 02:39 PM
1nate7's Avatar
1nate7
+1. I believe you need to get at least a 20mm spacer to have the studs built in.
Old Nov 15, 2007 | 03:01 PM
noodleman's Avatar
noodleman
that's true for ichiba spacers. but project kics makes 15mm spacers with studs built in (i have them).
I believe for H&R spacers you need to be 25mm before you gets studs built in...but i could be wrong.
Old Nov 15, 2007 | 04:57 PM
cheshirecat79's Avatar
cheshirecat79
That's correct, Noodle.
Old Nov 15, 2007 | 05:04 PM
WhiteZon19s's Avatar
WhiteZon19s
buy mine i ahve a set of 25mm hubcentric spacers with the studs built in 40$ shipped
Old Nov 15, 2007 | 05:38 PM
SS728's Avatar
SS728
So 25mm spacers, front and rear, with any spring drop, say gf's or s-techs, the flush will be good and tires will not rub?
Old Nov 16, 2007 | 05:58 AM
cheshirecat79
No, as that is a very broad statement. It also depends on the width and profile of the tire in the back that you are running. Generally the fronts will be fine with a drop.
Old Nov 16, 2007 | 06:09 AM
cambo350z's Avatar
cambo350z
just read all this
https://my350z.com/forum/media-share/273542-pics-front-lip-wheel-spacers-56kbeware.html
https://my350z.com/forum/media-share/311090-lowered-my-z-pics.html
Old Nov 16, 2007 | 06:51 PM
SS728's Avatar
SS728
Sorry, this is on all stock rims and tires. oem spec.
Old Nov 18, 2007 | 02:32 AM
MrGraphics's Avatar
MrGraphics
If you go with stock rims, unless the spacer is +20mm to hide the nuts, you'll have to knock out the old bolts and insert new bolts.
However, the bolts shown will not suffice for a bolt replacement. They are not the right type. They need to have little ridges around them and no taper.
If you are attaching a 15mm spacer with its own bolts to stock bolts, then you need a rim that actually is built to allow for the bolts to co-exist. See in the picture how my rims have a space for a bolt?
I just did this job, and I went with 15mm spacers and replaced the bolts. I didn't like the unclean finish and I also feel that the spacer/bolt method puts too much stress on the bearings.
Old Nov 18, 2007 | 07:04 AM
Watkins's Avatar
Watkins
I've been using H&R DRMs on my car for quite some time. No issues here.
Old Nov 18, 2007 | 08:26 AM
cheshirecat79
Agreed on the DRM series- it says 40-90 mm but mine are 25 and they're perfect.
IMO, on stock wheels, 25 mm all around is enough to give it that perfect flush look. Plus you don't have to knock out any other bolts.
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
