Loud and Horrible Ride...HELP!
Old Sep 4, 2007 | 06:51 PM
TurboTrey's Avatar
TurboTrey
Default Loud and Horrible Ride...HELP!
I have a '03 Performance with 58k miles and Nitto NT555's on it. The tread on the tires looks pretty good. I can stick my finger down in the grooves and I have to press a little to get down to the bottom. No idea what the depth is though. I don't think it's time for new tires based on the tread ware.
Now here is my problem...my car has a ton of road noise and I can feel every bump in the road. When I hit a small bump or hole I can feel it and the car has developed a ton of rattles do to this. What is causing the ride to be like this? I know the Z has a stiff ride but this is ridiculous.
What could be wrong? Is it my tires or shocks or all?
Old Sep 4, 2007 | 07:11 PM
PDX_Racer's Avatar
PDX_Racer
Just because you have tread doesn't mean that the tires are as hard as rocks (and will be extremely noisy as a result).
Old Sep 4, 2007 | 07:16 PM
What was the ride like 10,000 miles ago?
What have you changed?
Old Sep 4, 2007 | 07:18 PM
roast's Avatar
roast
you've got nittos? Time for new tires dude...
Old Sep 4, 2007 | 07:21 PM
z32 Outlaw Z's Avatar
z32 Outlaw Z
New tires + alignment FTW
solved my issue with road noise
Old Sep 4, 2007 | 07:36 PM
stereoneeds's Avatar
stereoneeds
i had nittos for about 2 years and didnt have as harsh a ride as you are describing. and i was on 20's.
Old Sep 4, 2007 | 07:41 PM
dkmura's Avatar
dkmura
General & DIY Moderator
I'd also check the Z's wheel bearings, as they can cause a lot of noise if worn. I have similar miles on my pre-order '03 track and ended up finding a badly worn rear bearing that caused a lot of noise. You don't want a catestrophic failure on one of those!
Old Sep 4, 2007 | 07:54 PM
sluggoZ's Avatar
sluggoZ
...worn rear wheel bearings is the culprit!
Old Sep 4, 2007 | 08:23 PM
slowpork's Avatar
slowpork
Will Nissan dealer check/replace wheel bearing for free under regular warranty ?
Old Sep 4, 2007 | 08:31 PM
lilaznxboi08's Avatar
lilaznxboi08
i have nt555s right now and i love them. i dont hear any road noise. i think its most likely your shocks, do you have lowering springs?
Old Sep 5, 2007 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
Only if you're still in the warranty period. It falls under the Powertrain 5y/50K warranty.
Old Sep 5, 2007 | 09:52 AM
Q45tech's Avatar
Q45tech
If heavier than oem wheels and tires were installed stressing the bearings, Nissan may reject bearing warranty.
Old Sep 5, 2007 | 12:37 PM
TurboTrey's Avatar
TurboTrey
I've had the car for a year and have put 10,000 miles on it. Everything is stock. I can't remember if the ride was any different a year ago but I don't think it was much better.
Old Sep 5, 2007 | 01:15 PM
Thanks.
Then what you are experiencing is a typical 350-Z ride, or a ride degraded by tires. Without driving the car, I haven't the faintest idea which it is.
Old Sep 5, 2007 | 04:09 PM
TurboTrey's Avatar
TurboTrey
Would new/better tires help out? It just feels like my car has no shock absorption and it sounds like it has no sound dampening. When I'm driving at highway speeds I can barely hear to talk on my cell phone and I have to turn my radio up really loud to be able to hear it.
My sister has a G35 sedan and it is very quiet and rides like a dream on rough roads.
Old Sep 5, 2007 | 04:38 PM
TurboTrey's Avatar
TurboTrey
So I just went out and looked at it and I saw that the right rear tire is worn very bad on the inside. The inside tread is almost smooth while the outside has a lot of the groove left.
So would this be covered by the alignment problem or am I out of luck and I just need to get new tires?
Car is an '03 with 58k miles on it.
Old Sep 6, 2007 | 12:26 AM
hotsonhk's Avatar
hotsonhk
I have the same problem. It is noisy as hell on the freeway, irritating and hard to hear the music. I bought new tires, just need to put them on and have the car aligned. The suspension is pretty stiff on the 350z stock, and I read on this forum that upgrading to the revised 06/07 suspension at least will make the ride better.
Does the 5yr/50k mile warranty apply to all vehicles? I have an 03 with 40k miles, does that mean I am covered? Second owner, bought car recently.
Old Sep 6, 2007 | 12:41 AM
SuperBlack350z's Avatar
SuperBlack350z
yup still covered.
Old Sep 6, 2007 | 04:24 AM
TurboTrey's Avatar
TurboTrey
I thought it was 5yr/60k?
Old Sep 6, 2007 | 06:22 AM
TurboTrey's Avatar
TurboTrey
So I looked this morning and the inside of the right rear tire is almost bald. If I get this aligned will the noise go away or do I need to get a new tire on there too?
Firestone said it is $69.99 for a front and rear alignment or lifetime for $149.99.
