Kumho Tires
Old Sep 11, 2007 | 02:20 PM
QM888's Avatar
QM888
Default Kumho Tires
Please help.
I want to change my stock size to be wider like 235/40/18 f and 265/35/18 r.
Have anyone had any prolem w/ tire sensor?
also, i see Kumho ecsta SPT have good user review? anyone owned these tire?
Old Sep 11, 2007 | 04:15 PM
bluespecv03's Avatar
bluespecv03
I have a friend with the SPT's on his S2000. They are an excellent tire with ALOT of grip, low noise, and a good looking tread pattern. Also cant really beat the price for the performance.
Ive had several other Kuhmo tires on various cars, including the Supra 712's and KH 11's and they have always been top notch. Very good wet and dry traction. Im disappointed to see they dont make the SPT's in the 245/45/18 size for my Z.
Go with the Kuhmo's. You will definetly be happy.
Old Sep 11, 2007 | 04:24 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
Originally Posted by QM888
Please help.
you're going to have an issue with the ecu / traction control because the tire wall is a higher # in the front and a smaller one in the rear.
i don't think i explained it correctly, but i bought my little brother 30 series in the rear and the front had 35 series and the ecu / traction control went nuts.
Old Sep 11, 2007 | 09:53 PM
PDX_Racer's Avatar
PDX_Racer
245/40R18F, 275/40R18R FTW (at least on my track wheels, 18x8F, 18x8.5R)
Old Sep 12, 2007 | 09:40 AM
simonfencer's Avatar
simonfencer
I have had Kumhos on two different vehicles, and was happy with them in both cases (still happy in one).
Old Sep 12, 2007 | 10:11 AM
bowzer6982's Avatar
bowzer6982
Do you happen to have an up close pic of how this setup looks?
Old Sep 12, 2007 | 10:26 AM
fiveninerzero's Avatar
fiveninerzero
I had Kumho Ecstas on my RSX, they were I'd say middle of the pack as far as traction was concerned, they struck me as the type of tyre that performs, then loses traction without warning. Some like that type of feedback, but me personally I'd like a little warning when I'm at the end of the envelope.
Also, wet traction was ok, I encountered the worse thunderstorm of my life on I-75 and I was still able to safely do 60 mph while other cars were skidding all over the place doing 10mph less than me.
Old Sep 12, 2007 | 10:30 AM
Ztalker's Avatar
Ztalker
+1
Old Sep 12, 2007 | 11:37 AM
QM888's Avatar
QM888
so I should go 245/40/18 front and 265/40/18 rear then I wont have problem w/ traction or VDC right? pleas advise.
my front wheel is 18x8 and rear 18x8.5
Old Sep 12, 2007 | 11:51 AM
Ztalker's Avatar
Ztalker
^you'll be fine with 275/40 rear and 245/40 front, they meet oem spec more or less.
here's how my 275/40/18 rear looksKumho Tires-general-tire.jpg
Old Sep 13, 2007 | 09:02 AM
rkd350z's Avatar
rkd350z
275/40/18
Kumho Ecsta MX
Old Sep 13, 2007 | 09:19 AM
terrasmak's Avatar
Best answer so far , 8.5 wheel is fine for the 265. Dunlop RE0050 , and federal tires both have a good tire in the proper size for you.
Old Sep 13, 2007 | 09:39 AM
QM888's Avatar
QM888
thanks for all your help and advises
Old Sep 13, 2007 | 09:50 AM
kennyl5123's Avatar
kennyl5123
you will feel soft side wall with 275/40/18. Try 245/40/18 front and 265/40/18 or 255/40/18 rear. Even though treadwear is 320. I only have it last 20k miles!!!
Old Sep 13, 2007 | 10:54 AM
QM888's Avatar
QM888
if i go 245/40/18 front and 265/40/18 rear, I will lower my car w/ ibach prokit spring. Would I have any problem w/ fender or suspension touch
Old Sep 13, 2007 | 12:32 PM
Ztalker's Avatar
Ztalker
i don't think you can get kumho in 255/40/18 or 265/40 /18.
Old Sep 13, 2007 | 01:31 PM
terrasmak's Avatar
Not at all , and you should be able to run a 20mm wheel spacer along with the drop to flush the wheels up a bit.
Old Sep 19, 2007 | 01:41 PM
QM888's Avatar
QM888
awesome...thanks for all your good advises.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
