Quick Check: Will this rub?
I want to check really quickly before I make the purchase today. Will 255/45/18 with offset of +35mm on FRONT rub on STOCK suspension?
Thanks!!
Thanks!!
Originally Posted by davidv
The numbers that you are giving me are unusual: tire size and wheel offset. What I need is wheel size.
Thanks!
Probably , my 255/40's with +33 are pretty close, and the 255/45 is taller than a normal rear tire.
Originally Posted by redlude97
thats going to be more tucked than stock, any particular reason you want to run such a setup?
Originally Posted by UltraYellow350z
The wheel size is 18 x 8.5. I am going to run 255 all around and wanted more profile [45] to cover my wheel gap. Its still within 3% of error for the speedo. I am just making sure I won't have any problems with rubbing.
Thanks!
Thanks!
Offset: +30mm
18 x 8.5. +35
The wheel that you have chosen fits 11 mm closer to the strut housing. I don't like it.
OEM Front wheel
Offset: +30mm
18 x 8.5. +35
Offset: +30mm
18 x 8.5. +35
Is it the tire width that is the problem or the tire height?
Hmm, I don't have any other choice with the rim. And I'm set on the rim. What do you recommend to do in this situation? Spacer or different tires size?
I am not a fan of spacers. If the wheel is free – take it. If you are buying wheels, then select one that fits better.
The problem is the wheel width and offset.
Do you have any recommendation on a tire size to go that won't rub?
My choices are basically:
(1) 245/40/18
(2) 245/45/18
(3) 255/40/18
(4) 255/45/18
I prefer higher profile to cover my wheel gap.
Thanks for the recommendations.
#1 , 245/40 since its an 8.5 wheel. If you want , throw a good quality spacer on later to bring it out to your liking.
350Z_Al
Oct 29, 2020 07:44 PM
