255/45/18 fit on Front?
Old Sep 16, 2007 | 08:37 PM
UltraYellow350z's Avatar
UltraYellow350z
Default 255/45/18 fit on Front?
Will 255/45/18 on a 18x8.5 +30mm wheel fit on the front with no problems?
Base w/ no brembo.
Quick checking before I make a purchase. Thanks!
Old Sep 16, 2007 | 10:27 PM
gsazabi's Avatar
gsazabi
I'm sure will fit. A bit odd combination of wheel/tire size and offset if you ask me..
If you really wanted to you can fit 275 tires in the front.
Old Sep 17, 2007 | 05:18 AM
UltraYellow350z
I agree, the offset is not great but it'll have to do. I simply wanted to run the widest tire on a rim possible (255).
Wow I didn't know our fronts could run 275. I'm sure you need a spacer for that application right?
Old Sep 17, 2007 | 07:11 AM
1nate7's Avatar
1nate7
A 255 will fit fine. A 40 series sidewall woud be a better match to the stock diameter though.
Old Sep 17, 2007 | 07:16 AM
UltraYellow350z
Thanks for the confirmation. Yeah I know a 40 would be a better match, the reason why I was going to go 45 was to cover up wheel gap and also theres a tire in that size right now thats on sale. I figure the 3% slower won't make a big enough difference to keep me from making the purchase as long as it fits.
Thanks!
Old Sep 19, 2007 | 01:27 PM
QM888's Avatar
QM888
i thought front stock wheel is 18x8.0 not 8.5
r u sure about that? i know rear is 10x8.5 wheel size for stock
Old Sep 19, 2007 | 01:35 PM
UltraYellow350z
I'm actually talking about aftermarket wheels
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
