New 19" Rims and now I get the slip light..
Old Sep 18, 2007 | 10:12 AM
pgn29's Avatar
pgn29
Default New 19" Rims and now I get the slip light..
Help, please....
I just put 19" on my car and I am getting the slip light come on. The tire pressure light is also on b/c the tire shop couldn;t use tire monitoring valves. Any ideas. My wheels are Ruff racing 19x8.5 in front with 245/30/19 and rear with 19x9.5 275/35/19.
In dire need of answer,
Thanks - Paul
Old Sep 18, 2007 | 10:24 AM
THEDUKE's Avatar
THEDUKE
I believe you should have used 245-35-19 in the front to keep the slip light from turning on, but am not sure. As far as the tire monitors, they should have had no problems mounting them on the Ruff wheels since they are 1 piece wheels. You may have to go to another shop if this shop does not know how to mount TPS sensors on other wheels. The only time you have issues mounting the TPS sensors is when being used with multi-piece wheels, even then you can use the banding method.
Old Sep 18, 2007 | 10:26 AM
Ghost 350z's Avatar
Ghost 350z
its because of the diff size in height of the tire just like THEDUKE said. I used to get it all the time until I started to run 35s all around
Old Sep 18, 2007 | 10:34 AM
Nexx's Avatar
Nexx
ahh, as long as your fronts are shorter then your rears, you should be good. not sure why you're getting the slip with that setup. are you sure you dont have 35 series up front and 30 series rear?
Old Sep 18, 2007 | 10:37 AM
Ghost 350z's Avatar
Ghost 350z
doh...i missed that
Old Sep 18, 2007 | 10:39 AM
Bahraini350Z's Avatar
Bahraini350Z
my set up is 19x8.5 & 9.5, running 245/35 & 275/35 with no problem
as the guys said, change the fronts.. sorry
Old Sep 18, 2007 | 11:15 AM
Miami-Z's Avatar
Miami-Z
im having the exact same problem and i also have ruff wheels 19x8.5f245/35/19 and 19x9.5R 275/30/19. my car stalls when driving then slip and vdc come and stay on
Old Sep 18, 2007 | 02:00 PM
Edit: I looked at the difference in circumference, and it is 7.2 percent. This may be too much for VDC. Someone check my arithmetic.
Old Sep 18, 2007 | 02:32 PM
noodleman's Avatar
noodleman
you shouldn't be looking at the sidewall, but overall diameter/radius. i believe this is outside of the threshold for tire staggering that the VDC can handle.
Old Sep 18, 2007 | 02:35 PM
LAKERSFAN's Avatar
LAKERSFAN
probably because youre running the 275/30 in the rear
Old Sep 18, 2007 | 02:59 PM
DavesZ#3's Avatar
DavesZ#3
He's got a difference of almost 1.8" between the fronts and rears. The "generally accepted" range is 0.25 to 0.75" stagger from front to rear. My guess is that the large difference is outside what his VDC can handle. You'll probably find a few people here that will state that those sizes worked for them, and it's probably true. There has always been some variation in what works on one car versus another - probably related to tire brand as they are not exactly the same.
Old Sep 18, 2007 | 03:02 PM
Volk350Z's Avatar
Volk350Z
Master
yup... sidewall # is just a percent of the width.. not all 30 series side walls are the same if the width is different...
Old Sep 18, 2007 | 06:26 PM
pgn29's Avatar
pgn29
I checked this website (http://www.dakota-truck.net/CGI-BIN/TireCalc.cgi) and it says that my difference in height is
Tire Rim Size Width Height Height Difference Full Analysis
275/30 R 19
(25 x 10.83 x 19) 19" 10.83" (275mm) 25.50" (647.60mm) -0.26" (-6.50mm)
275/30 R 19.5
(26 x 10.83 x 0) 19.5" 10.83" (275mm) 26.00" (660.30mm) +0.24" (+6.20mm)
Old Sep 18, 2007 | 06:52 PM
DavesZ#3's Avatar
DavesZ#3
275/30 R 19
275/30 R 19.5
Huh?
Old Sep 19, 2007 | 04:51 AM
Moroccan_Mole's Avatar
Moroccan_Mole
275/30 R 19
275/30 R 19.5
why exactly are you comparing a 19" wheel with a 19.5" wheel?
Old Sep 19, 2007 | 09:55 AM
Volk350Z's Avatar
Volk350Z
Master
this is how you do it..
WIDTH (divide) .HEIGHT% (time) 2 then (divide) by 24.5 (for milimeter to inch) + size of tires, then you will get the over height.
example (275/30/19) 275 / .30 = 82.5mm x2 = 165.00mm / 25.4 (convert to inch) = 6.496" + 19" = 25.496
Old Sep 19, 2007 | 01:18 PM
FRLDYZPIMPN's Avatar
FRLDYZPIMPN
Need to have 35 series front and rear. Otherwise, slip light kicks in like a *****.
Old Sep 19, 2007 | 02:35 PM
terrasmak's Avatar
If they have VDC , TCS or a base with nothing, is also a huge factor.
Old Sep 19, 2007 | 07:06 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Yep, the overall diameters of your tire size selection front vs. rear are definitely outside the acceptable parameters for the VDC. Like the others said, if you're running 245's in front and 275's in the rear on 19" wheels, they should both be 35 series tires.
There is a sticky about this too: https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
loudtoyz
Apr 6, 2023 04:52 AM
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
