Slip control is activating whats going on???
Old Sep 21, 2007 | 11:13 AM
lawman0210's Avatar
lawman0210
Exclamation Slip control is activating whats going on???
So I am driving down the highway in a straight line when my cars seems like it shut off. I look down and I see my slip indicator flashing. Whats going on? I have had it coming on when going on hills and curves at fast speeds but not while driving a straight line. Only thing I can think of is that i did get a great deal on four wheels and tires. They are not a staggered fit. They are straight 8.5 wide. Can this cause it?
Old Sep 21, 2007 | 11:22 AM
Bigman095's Avatar
Bigman095
Are they taller than you others?
Old Sep 21, 2007 | 11:25 AM
DavesZ#3's Avatar
DavesZ#3
If your car came with a staggered setup and your new setup isn't staggered, then you run the risk of VDC/TCS kicking in when you least expect it.
BTW - it has nothing to do with the wheel width, it's the tire OD that matters.
Old Sep 21, 2007 | 11:36 AM
StreetOC192's Avatar
StreetOC192
VDC is set up to monitor a staggered set up. And deviation from what it is set up to tollerate will cause the VDC to activate because it thinks you are losing traction. There is a sticky thread at the top of the Wheels & Tires section that explains all about the VDC and proper tire sizes.
Old Sep 21, 2007 | 12:05 PM
Spike100's Avatar
Spike100
What size tires are you running?
--Spike
Old Sep 21, 2007 | 12:06 PM
lawman0210's Avatar
lawman0210
20" 235 20 35 i believe
Old Sep 21, 2007 | 12:11 PM
lawman0210's Avatar
lawman0210
Can I turn off or disable the VDC?
Old Sep 21, 2007 | 12:46 PM
bailey bill's Avatar
bailey bill
Do you have an Owner's Manual?
bill
Old Sep 21, 2007 | 12:53 PM
DavesZ#3's Avatar
DavesZ#3
Have you noticed that little VDC Off button under the dash by your left knee?
Old Sep 21, 2007 | 04:17 PM
Spike100's Avatar
Spike100
That's not enough information for us to help you.
The metric tire sizing system represents a tire size as:
[section width (mm)] / [aspect ratio] - [rim diameter (inches)]
Questions:
1) It sounds as though you have 20" wheels... is that right?
2) Is your tire size 235/35-20" ? That doesn't sound right since this would be narrow for a wheel with a width of 8.5" (especially a 20" diameter wheel).
3) Do the front and rear tires have the same overall diameter?
--Spike
Old Sep 21, 2007 | 06:06 PM
al v's Avatar
al v
I have 255/35-20 in front , and 285/30-20 rear.My front tire is bigger than my rear tire ,and I never had a VDC light flashing ,even in long trips.
Something is wrong in your car.......
Old Sep 21, 2007 | 06:20 PM
Spike100's Avatar
Spike100
But... Are your tires the same as lawman2010's?
We don't know what tire size(s) he's running.
--Spike
Old Sep 22, 2007 | 07:54 AM
lawman0210's Avatar
lawman0210
I have 245 35 ZR 20's. I dont have a vdc button only a traction control. It is going crazy now. It turned on a few dozen times driving on a 2 hour trip last night. I just had the brakes changed when it started to happen. Could this have down it some how? How does the vdc measure the rotation of the tire? I noticed that since my brake change I have these small tabs sticking of the brake housing. They look lie they fold down and suppose to lock down on a tab but wont since the brake job. I dont know what they are I will try to get a picture of them. I appreciate all the help.
Old Sep 22, 2007 | 08:13 AM
You do not have VDC so the problem is the rear axle.
Are you certain that the wheels and tires on the rear axle are the same size?
Check the tire pressure. Make sure they are the same.
New tires are slippery. Put 200 miles on the tires. See if that solves the problem.
Old Sep 22, 2007 | 11:58 AM
lawman0210's Avatar
lawman0210
Ok what is the "slip" indicator mean? I drove in the rain today approx30 miles or so with no occurances.
Old Sep 22, 2007 | 04:53 PM
Spike100's Avatar
Spike100
You still are not providing enough information for us to help you.
You said: “I have 245 35 ZR 20's.”
Is this the tire size on the front, the rear; or are all your tires this size? If all four tires are the same size (same OD), your problem is just that.
The SLIP light means TCS is activated. Since you do not has a button labeled “VDC” but you see the SLIP light, your car has TCS but not VDC.
--Spike
Old Sep 22, 2007 | 08:10 PM
lawman0210's Avatar
lawman0210
they are all the same size. It rarely slipped until after I got the brakes changed (all four) now it is slipping all the time even in a straight line
Old Sep 23, 2007 | 01:49 PM
Spike100's Avatar
Spike100
Well… I’m stumped. I don’t know how a brake replacement would cause TCS to start malfunctioning, but I suppose it’s possible. Since you report having the problem (albeit to a much lesser degree) before installing new brakes, there is something other than the new brakes at work here.
I drove a 2003 Enthusiast model which had an intermittent engagement of TCS for no good reason (just as you report). This happened after installing new tires (Avon) matching stock sizes (the 2003 Enthusiast came with 17” wheels). The problem was there for a month or so, and then it went away. I can only assume it was the slippery grease on the new tires that wore off after a few hundred miles of driving. TCS is quite sensitive and activates quickly.
--Spike
Old Sep 24, 2007 | 07:13 AM
lawman0210's Avatar
lawman0210
After turning off the traction control I drove 150 miles with no occurances. I guess it is being caused by the traction control not vdc. Its weird its either goes crazy or works fine. One other thing while driving a straight line every evening going home I have it do it in the same spot every night. Straight road, no bumps etc. Can an electronic interference of some sort cause this to occur?
Old Sep 24, 2007 | 05:08 PM
Spike100's Avatar
Spike100
WTF?
___________________
Re> “After turning off the traction control I drove 150 miles with no occurances. I guess it is being caused by the traction control not vdc.”
Geez… We have already established the fact that you do not have VDC on your car. Why in the “H” do you keep mentioning VDC? And… Of course if you turn TCS off, you will not experience traction control engagement. Duh!
___________________
Re> One other thing while driving a straight line every evening going home I have it do it in the same spot every night. Straight road, no bumps etc. Can an electronic interference of some sort cause this to occur?”
No, that won’t happen.
___________________
My nature is to try being helpful, but your posts are beginning to sound like a fake. Sorry, but I’m off this thread.
--Spike
