cant decide between which tires
Old Sep 24, 2007 | 04:21 AM
vtb11's Avatar
vtb11
Default cant decide between which tires
falken 452 or nitto nt555? both are pretty much same in rating, cept nitto have z, falkens have y
same price for hte most part... but i havent had any experience with either one, so i was hoping i could get some input from personal experiences
or any other models that i could get for 150-160/tire if u guys have recommendations
thx
Old Sep 24, 2007 | 04:34 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
thx
Stay away from Nitto 555. Almost everyone that has totalled there Z in the wet had these tires on them. They have terrible ratings for wet traction. Go look at the BFG Gforce or the Goodyear GS-D3's.
Old Sep 24, 2007 | 04:52 AM
vtb11's Avatar
vtb11
yikes... definitely will now
ive generally heard falkens were good.. any bad reports of them out there?
ill check out those bfgs and goodyears
Old Sep 24, 2007 | 05:50 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Falkens are good for a cheap tire, but personally wouldn't buy them myself.
Old Sep 24, 2007 | 05:54 AM
resauto's Avatar
resauto
my falken 452s were nortorious for getting bubbles
Old Sep 24, 2007 | 10:35 AM
vtb11's Avatar
vtb11
well thats not comforting lol... guess ill give it a try for now since i am short on $ until after xmas
should i go with 225/35, 245/35
i have oem 19"s and tein s.techs... so im a bit worried that if i go 35profiles, itll be too low?
Old Sep 24, 2007 | 10:38 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Well I just saw on another forum someone saying those Falkens blow out all the time. So I personally still would not purchase those either. You can get other tires that are cheap and good. Like the BFG Gforce. Or even cheaper and good tires are the: General Excclaims. I highly recommend these! http://www.tirerack.com/tires/tires....el=Exclaim+UHP
I had these on my G35 and they were pretty nice tires.
and the BFG link
http://www.tirerack.com/tires/tires....ce+T%2FA+KDW+2
Old Sep 24, 2007 | 10:51 AM
vtb11's Avatar
vtb11
oh wow, those are well rated with a very good price...
very tempted to order now... but anyone have input on whether to go with a 35% vs 40% profile with my setup? (oem 19s w/ s.techs)
Old Sep 24, 2007 | 10:53 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
oem 19s? Your G came with 18s till 2005 it came with 19s. So please clarify?
Old Sep 24, 2007 | 10:58 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
18" 7 spoke (2003/2004 optional 2005+ Coupe std)
Front & Rear: 18"x8" +30mm offset
18" 5 split spoke (2005+ Sedan optional)
Front & Rear: 18"x7.5" (+45mm)
19" 5 split spoke (2005+ Coupe optional)
Front: 19"x8" +30mm offset
Rear: 19"x8.5" +33mm offset
Either stock size, or 245/35/19 and 255/40/19 would be the only safe choices
Old Sep 24, 2007 | 10:59 AM
Triple8Sol's Avatar
Triple8Sol
Those Nittos are GARBO! Those Falkens have great reviews.
Old Sep 24, 2007 | 11:04 AM
vtb11's Avatar
vtb11
i am trading my 18s for oem 19s
they have 225/40, 245/40 on them right now, but i was either going to stick with that same tire size or go to 245, 255... but i have a hard time finding the 255 and higher in 40% profiles
Old Sep 24, 2007 | 11:07 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Hmm....not sure then. You don't want the VDC to mess you up. I would ask the G35driver guys to see what sizes have worked on those wheels to get a idea.
Old Sep 24, 2007 | 11:08 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
What you could always do, is go to miata.net and use the tire calculator and put in the stock sizes. Then adjust it up and down till you find sizes that fit under 2% + or - of the stock size. Make sure both are either + or both - when you do it. If you give me a few I can do this for you.
Old Sep 24, 2007 | 11:11 AM
vtb11's Avatar
vtb11
yeah, ive had a post over there for a while but the actively replying folks are a bit less than over here since theres a lot more members in the Z forum... some say i can go 245, 265, while others say 245, 255, then others say stick to stock
hah, so im trying to find more clarification on teh whole matter... my main concern right now is if my car will be too low if i go with 35% profiles vs stock 40%
Old Sep 24, 2007 | 11:14 AM
vtb11's Avatar
vtb11
actually, what ive been using is http://www.rims-n-tires.com/rt_specs.jsp
it has a nice chart of comparable sizes and such... but it doesnt really help me decide which is "safe and recommended" so thats why i was asking around
Old Sep 24, 2007 | 11:20 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
225/40/19 vs
245/35 shows it being 1.3% to fast compared to stock
255/35 shows it being 0.2% to slow compared to stock (this one looks like a better match imho.
245/40x19 stock vs
255/40 shows it being 1.2% to slow compared to stock
275/35 shows it being 0.5% to fast compared to stock.
Just some ideas...take a look at the link below and play with it. You need java. Just make sure you stay under 2% difference between front and rear.
http://www.miata.net/garage/tirecalc.html
Old Sep 24, 2007 | 11:37 AM
vtb11's Avatar
vtb11
ahhh i finally understand what they mean when they said +/- 2% difference.. i thought it was the difference between stock front vs new front...
so if i got a set and fronts were 3.5% slower and rears were 3.2% slower, itd be ok since theyre only .3% difference...
bc im having a hard time finding matching brand & size for 245/35 & 255/40... so i was thinking of sticking to stock size, but lower profile...
so, 225/35 & 245/35
Old Sep 24, 2007 | 11:39 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yes you can do that. But going lower profile means more gap and less tire to protect your wheels. Just a thought.
Old Sep 24, 2007 | 11:41 AM
vtb11's Avatar
vtb11
yeah... that is what worries me at the moment... if those general exclaims had 40% profiles, id snag them, but on the site they have only 35, and i did a quick search and only found 35%s for hte most part.. ill be doing more searching later tonight to hopefully find some 225/40, 245/40s
thanks a ton for your help thus far btw
