SLIP light coming on while driving. Help!
Old Sep 26, 2007 | 07:38 PM
cnynracer1's Avatar
cnynracer1
Default SLIP light coming on while driving. Help!
Hey guys,
I have an 05 Track, with stock wheels. I recently replaced my rear tires with 245/45/18's (stock size) General Extremes. My front tires have never been replaced, and are at about 40% tread left.
Now the SLIP light comes on while driving on the freeway. I always thought if we stuck with stock size tires, the TCS would not get upset.
I need your advice guys. Should I buy a set of the same tires for the front? Will that help?
Thanks In Advance!
Old Sep 26, 2007 | 07:43 PM
gsazabi's Avatar
gsazabi
Drive for a few hundred more miles and see if it still does that.
New tires are usually slippery until driven for 300-500miles.
BTW never heard of General Extremes..but they sound like cheap tires...
Old Sep 26, 2007 | 07:48 PM
black06z's Avatar
black06z
yah, still gotta wear out that top covering on the tread. I only replaced my rear tires just like you, and had the slip light coming on while taking some corners, in the beginning. After a few weeks, much better like that.
Old Sep 26, 2007 | 07:56 PM
350Zimo's Avatar
350Zimo
here is the remedy, go to an empty parking lot , turn the TCS off, and burn rubber till dawn, it helped with my toyos,
Old Sep 26, 2007 | 08:05 PM
racerfreakxxx's Avatar
racerfreakxxx
hell yea... burn rubber till you cant see infront of you and you know you'll be good, lol... just spin them for a little bit and you should be fine
Old Sep 27, 2007 | 07:18 AM
cnynracer1's Avatar
cnynracer1
Thanks Guys! And BTW, they are General Exclaim's not Extremes, my bad.
They are actually very good tires for my cheap *** self. They got high reviews on tirerack.com, and at $130 a piece, I couldn't resist
Off I go to try burning out
Old Oct 20, 2007 | 11:08 AM
Vin Diesel's Avatar
Vin Diesel
The car you purchased is a fine turn machine don't put cheap or under rated tires on it. This car is known for it's incredible handling performance don't compromise it's integrity you might loose it in a corner.......
Old Oct 20, 2007 | 11:47 AM
cnynracer1's Avatar
cnynracer1
Thanks for the tips Vin, but these are good tires. Z-rated, and grip better than the OE tires.
Obadabot
Jun 18, 2023 11:31 PM
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
