I have an offset issue and I need some opinions.
Old Oct 3, 2007 | 06:03 PM
G35JCC's Avatar
G35JCC
Question I have an offset issue and I need some opinions.
Here is some history to note:
This is on a 07' G35.
I recently had new GTS's installed. Offsets are +17F, +18R (9.5F, 10.5R). Originally we tried to fit a 295 on the rear but had serious rubbing issues(even with fender rolling). The car has been dropped an inch and more neg. camber was out of the question. I'm f/i so more neg. camber=less traction. Anyway we put 285's on and they worked with no rubbing. My issue is that the wheels/tires stick out the fender about a 1/4" and I want 295's and preferrably 305's. So to be able to run that wide of tire I need higher offset. Plus I want my tires and rims to be as close to flush as possible w/o rubbing. I have decided to go with a +37 with 107mm lip. Don't question those numbers as they came directly from Ray's fitment chart. That manages to be nearly 3/4" tucked compared to the +18. Here is my dilemma:
1. THis seems to be the offset to run when using wider tires, why don't more people run this combo when desiring more traction?
2. Could it be that I have lost it and have no clue?
3. Will this offset likely rub the inside fender well now?
4. If someone has a better setup in mind please let me know.
This entire offset issue/debate has given me a monstrous case of diarrhea and I'm now going to relieve myself.
Thanks for the help.
Judson
Old Oct 3, 2007 | 06:08 PM
Nexx's Avatar
Nexx
it really sounds for what you want you need to get your fenders cut. get them cut and run a higher offset in the mid to high 20's and you shouldnt have issues with 295's. with this setup you should be able to avoid rubbing and still have a low enough offset to give you the flush look.
Old Oct 3, 2007 | 06:15 PM
Alberto's Avatar
Alberto
Cranky FI Owner
To run a 305 with no issues, you need something around +28-32....that new offset sits wayyy to far in IMO and will look silly. On another note, you wont see a big differnce from 285-305 in terms of traction believe it or not on 99% of street tires. If your spinning that bad a set of 275 drag radials will hook better than 305's street tires. I run 285/35 with-1 camber and lowered +22 with no rubbing, and no traction in 1st-2nd, just live with it
Old Oct 3, 2007 | 07:11 PM
redlude97's Avatar
redlude97
+28, like I told you on driver is a much better option
Old Oct 3, 2007 | 08:46 PM
joekool's Avatar
joekool
how is that possible?? I got 19x10.5's on stock suspension but with the same offset, camber and tyre sizes and mine rubs like hell (need to roll the lip)...
Old Oct 3, 2007 | 09:33 PM
redlude97's Avatar
redlude97
Maybe his fenders are rolled...
Old Oct 3, 2007 | 10:16 PM
joekool's Avatar
joekool
Yeah I may also have confused +22 with offset instead of how much it was lowered.
Old Oct 4, 2007 | 02:39 AM
VIZAGE's Avatar
VIZAGE
I know Alberto's fenders are rolled and I believe he's dropped just over an inch.
Old Oct 4, 2007 | 05:45 AM
G35JCC's Avatar
G35JCC
Got it. Now to see if I can cancel that order and get some 30 offset. Thanks for the help.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
