I have searched, but could use some help on spacers
Old Oct 10, 2007 | 12:52 PM
ohavemercy's Avatar
ohavemercy
Default I have searched, but could use some help on spacers
I have 18x8.5 front and 18x9.5 rear wheels what size spacer do you recommend for a flush look. Thanks in advance for the help!
Old Oct 10, 2007 | 12:54 PM
Tubbs's Avatar
Tubbs
you need to give the offets or your wheels, and tire sizes.
Old Oct 10, 2007 | 12:55 PM
ohavemercy's Avatar
ohavemercy
Sorry Offset : 32mm(front) & 35mm(rear), 245x40x18
Old Oct 10, 2007 | 01:01 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I'd say 25mm on all four.
Old Oct 10, 2007 | 01:07 PM
Tubbs's Avatar
Tubbs
those would work.
Old Oct 10, 2007 | 01:15 PM
VO...'s Avatar
VO...
Administrator
Don't forget about new studs...
Old Oct 10, 2007 | 01:18 PM
gregtotheb's Avatar
gregtotheb
https://my350z.com/forum/showthread....t=25mm+spacers
post 4.
Old Oct 10, 2007 | 01:29 PM
dutchboy350Z
Finally some go
Or you can get the Project Kicks which bolt on to your existing studs.
Old Oct 10, 2007 | 01:45 PM
VO...'s Avatar
VO...
Administrator
I've never seen those. Gotta link?
Old Oct 10, 2007 | 01:48 PM
gregtotheb's Avatar
gregtotheb
http://www.optionimports.com/kiwhsp5x1115.html
they come with studs attached to the spacer, and bolts to attach to your stock studs. the studs that come with the spacer replace your stock ones.
Old Oct 10, 2007 | 01:56 PM
VO...'s Avatar
VO...
Administrator
That is a pretty sweet design....
Old Oct 10, 2007 | 01:58 PM
redlude97's Avatar
redlude97
FYI, all brands of spacers over 25mm use that design, H&R, Kics, Eibach, Ichiba etc.
Old Oct 10, 2007 | 02:00 PM
Tubbs's Avatar
Tubbs
That's what I've got. They work great. Just put some loc-tite on your original studs when putting them on.
Old Oct 10, 2007 | 02:01 PM
dutchboy350Z
Finally some go
Very good quality. I have 20mm on my rear wheels.
Old Oct 10, 2007 | 02:04 PM
dutchboy350Z
Finally some go
+1 Yeah I forgot to mention that anything under 25mm (for most of the spacers) isn't safe enough to just bolt on. That's when they supply you with longer studs.
Old Oct 10, 2007 | 02:06 PM
dutchboy350Z
Finally some go
I actually didn't even use loc-tite. After about 50 miles I took off the rears and re-torqued the spacer bolts. To my surprise none of them needed to be re-torqued. I've driven over 5000 miles since and no wobble or shake at all.
D_Rod
Sep 29, 2015 04:42 AM
samansharif
Sep 25, 2015 12:31 PM
