Need a little help Wheel gurus!!
Old Oct 20, 2007 | 07:07 PM
Try&keepup's Avatar
Try&keepup
Default Need a little help Wheel gurus!!
Just about to order some rims and need a little info. The rears will be 18x9.5 with a 25 offset. The fronts are 18x8 with a 25,35, or 45 offset and i can't figure out which offset will match the back. i just read about a hundred different tire threads and can't figure it out. Thanks for the help.
Old Oct 20, 2007 | 10:56 PM
terrasmak's Avatar
25 for the front , will match just fine
Old Oct 20, 2007 | 10:57 PM
gregtotheb's Avatar
gregtotheb
+1 you can go lower on the rears if its available what kind of wheels?
Old Oct 21, 2007 | 05:22 AM
Try&keepup's Avatar
Try&keepup
Thanks for the info, looking at tenzo DC-6 version 2
Old Oct 21, 2007 | 11:24 AM
Try&keepup's Avatar
Try&keepup
Old Oct 21, 2007 | 12:36 PM
seriously240's Avatar
seriously240
18x8 on a 350z?
Old Oct 21, 2007 | 12:55 PM
Try&keepup's Avatar
Try&keepup
no 18x8.5 front 18x9.5 rears
Old Oct 21, 2007 | 01:19 PM
phorbo007's Avatar
phorbo007
Go with the 25mm if that's the lowest offset available. I would even add 10-15mm spacers for the fronts and rears to go along with that for a more flush look.
Old Oct 21, 2007 | 07:18 PM
Try&keepup's Avatar
Try&keepup
thanks for all the good advice
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
