base 07 has tire pressure sensors??
Old Oct 25, 2007 | 11:04 AM
TRD2Nismo's Avatar
TRD2Nismo
Default base 07 has tire pressure sensors??
I have and 07 base and the low tire pressue light came on, I thought the base 07s didn't come with this feature...havnt checked my tire pressure im still at work...it went on, on the way to work...is this a clitch or does the 07 come with tire pressure sensors??
Old Oct 25, 2007 | 11:09 AM
Smawg350's Avatar
Smawg350
Comes with them
Old Oct 25, 2007 | 11:10 AM
zand02max's Avatar
zand02max
They come with them!
Old Oct 25, 2007 | 11:30 AM
maestro1991's Avatar
maestro1991
Mine came on last week. Checked the pressure~31PSI. I inflated the tires to 35PSI (max allowed) and the light went away.
Old Oct 25, 2007 | 12:18 PM
ckthepilot's Avatar
ckthepilot
my 07 has TPS as well and its a BASE.
Old Oct 25, 2007 | 01:38 PM
Z04's Avatar
Z04
you didn't check your owner's manual?
Old Oct 25, 2007 | 03:03 PM
blazed54's Avatar
blazed54
do they ever?
Old Oct 25, 2007 | 03:27 PM
dyss's Avatar
dyss
yeah it comes with TPS... Pressure should be 35 psi btw
Old Oct 25, 2007 | 04:45 PM
pahaek's Avatar
pahaek
i have low pro tires on 20s and i just got the light removed cuz no matter wat pressure u have... EVERY time u hit a bump they come on.
Old Oct 25, 2007 | 05:33 PM
terrasmak's Avatar
Just get 19's , it will look better anyhow
Old Oct 25, 2007 | 05:41 PM
crg914's Avatar
crg914
As of 2007 it is mandatory that all vehicles come equipped with Tire Pressure Monitoring Systems.
Old Oct 25, 2007 | 06:00 PM
Bary626's Avatar
Bary626
You are partly correct. 07 come with sensors for what good they are?
They took away on 07's monitor that showed PSI in all 4 tires.
Now when one tire goes low or flat it does not tell u which tire.
You have to get a gauge & check all 4 tires yourself to see which one? SUCKS!
Old Oct 25, 2007 | 06:17 PM
crg914's Avatar
crg914
Oh boo hoo. That's the best thing to do anyway. The sensors are calibrated for each corner and if you get new rims and the shop doesn't pay attention to which sensor comes off which wheel and mix them up, your readings will be false anyway. I've had customers come in claiming to lose pressure in the right front tire because that's what the gauge says, when it's actually left rear.
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
