Anyone's stock Potenza's last as long as mines?
Old Nov 8, 2007 | 11:10 AM
  #41
Bevo's Avatar
Bevo
I'm at 19k miles, all 4 tires need to be replaced. Especially the 2 fronts, both inner tread are gone.
Old Jul 12, 2008 | 05:53 PM
  #42
j.arnaldo's Avatar
j.arnaldo
The feathering issue has something to do with it, I guess; if your beaZt doesn't suffer from it, I suppose they'll last a lot. Mine are nearly gone at 16,OOOk; they still have some meat to them, but I'm getting some new Regattas (Good Year).
Old Jul 15, 2008 | 11:35 AM
  #43
350zWVU's Avatar
350zWVU
5,000 here for my rear Potenza's. Down to 3/32nd and am changing them out soon. Both Bridgestone and Nissan will not deal with me. I am not a "Spirited" driver. Anyone know if there is any relief from either Bridgestone or Nissan in getting the rears replaced under some type of warranty?
Old Jul 15, 2008 | 11:52 AM
  #44
nlzmo400r's Avatar
nlzmo400r
thats probably because u need an alignment
I have 6800miles on mine and they're holding up fine, either way they're getting replaced with the new wheels get here
Old Jul 15, 2008 | 02:38 PM
  #45
rockinbboy's Avatar
rockinbboy
wtf?
I pulled my stockers off with 21k miles. Rears had 4/32 thread left and fronts had 6/32.
If you don't know spriited driving, then what kind of driving do you do? You buy the car new? If used, were the tires new or used? something doesn't make sense.
Old Jul 15, 2008 | 05:19 PM
  #46
Spike100's Avatar
Spike100
If you drive “normally” (and this is a very subjective statement), you can expect your rear OEM tires to last at least 20K miles, but never past 30K miles.
Mileage on the front tires is a wiggly issue when you include the front tire featuring problem (which is solved for any Z). If you do experience tire-feathering (and no one has this problem now if they follow Nissan’s solution for this), your fronts will be worn out at 20K miles, but go farther if your alignment is correct.
--Spike
Old Jul 15, 2008 | 05:20 PM
  #47
davids's Avatar
davids
F U StuLax18
25,000 miles + 4-5 auto-x events.
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
