wheel spacers
Old Oct 30, 2007 | 12:37 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default wheel spacers
how safe are these wheel spacers with studs already on? I need to bring the stock 06 wheels out and my only option is 25mm w/o changing the stock studs. I want to get 20mm all around but they require changing the stock studs i dont know what kind of problem i will run into changing them. Now project kics all in back order.
Old Oct 30, 2007 | 12:39 PM
iStan's Avatar
iStan
ZR
The studs aren't TOO bad. It's just a little more intensive than a brake pad job. I've run adapters on my truck and it took a beating and kept on going.
Old Oct 30, 2007 | 12:46 PM
JasonZ-YA's Avatar
JasonZ-YA
i say 25mm front and back....im running 20mm front and wish i got 25mm for front....im running stock 06 wheels..
-j
Old Oct 30, 2007 | 12:59 PM
Ilov350ZEE's Avatar
Ilov350ZEE
my concern here is safety dont want any wheel to just come off or get any vibration. What brand do you have jason, did you change the stock studs, how hard ws it?
Old Oct 30, 2007 | 01:01 PM
meaj82's Avatar
meaj82
I had F25mm R30mm(project kics) on my stock 06 wheels. It sat perfect with the hotchkis springs. Now with the rays I had them switched with due to a little more rubber on the back.
Old Oct 30, 2007 | 01:23 PM
JasonZ-YA's Avatar
JasonZ-YA
that wont happen, i have project kics also, very good quality, studs are mounted on the spacers and solid...so i didnt change the stock studs....reason being, i want to run the stock 06 wheels to keep a low profile, but i put aftermarket wheels on when i got to drift/track events, and i just cordless impact off my wheels, spacers, whatever i need for whatever wheel combination i have at the time.
- j
Old Oct 30, 2007 | 01:24 PM
JasonZ-YA's Avatar
JasonZ-YA
ya, meaj82 set up sounds nice. im hope'n to meet up with him this thursday at the Ih-10 meet here local to check it out....flushness and all....
- j
Old Oct 30, 2007 | 04:25 PM
meaj82's Avatar
meaj82
Heres some of my links w/ the stock wheels on:
F25mm, R30mm rear hotchkis springs:
https://my350z.com/forum/media-share/290543-new-cross-drilled-slotted-rotors-and-project-kics-spacers.html
https://my350z.com/forum/media-share/291399-new-updated-pics-just-washed-and-detailed.html
Old Oct 30, 2007 | 04:31 PM
meaj82's Avatar
meaj82
- j
I'm hoping to be there, 9:30 is close to my bedtime lol. I have to get up at 4:30am the next day. If I do go, it will be more towards the early evening.
Old Oct 30, 2007 | 05:39 PM
Ilov350ZEE's Avatar
Ilov350ZEE
/\thanks for posting those pictures. i think i'll get 25mm all 4
Old Oct 31, 2007 | 07:54 AM
cambo350z's Avatar
cambo350z
i got 25mm H&R rear and 20mm eibach front. eibach makes a few different types..one where you replace the studs and ones with them attached. I got the 20mm with ones attaches. mynismo.com sells them.. they are designated by 4 in the end..type 4 https://my350z.com/forum/media-share/311090-lowered-my-z-pics.html
Old Oct 31, 2007 | 09:58 AM
2 low Z's Avatar
2 low Z
That's pushing it man. I tried H&R 20 mm on my stocks in the rear and could only get around 6 turns I think. Be safe and just replace your studs, shouldn't cost you more than 100.
Obadabot
Jun 18, 2023 11:31 PM
