Aggressive Wheels and Stretched Tires....Welcome
Old Jan 23, 2010 | 09:32 AM
  #5841
350z2go's Avatar
350z2go
maybe a 245 in the front i just cant c where its rubbing!
Old Jan 23, 2010 | 09:34 AM
  #5842
JonnyB504's Avatar
JonnyB504
Originally Posted by 350z2go
i gonna go with 275 in the rear but i like how it looks with the spacers and the rear is rolled -2 neg camber right now
I know someone with 275 in the rear with -3.5 camber on a 10.5 +0 and he still rubbed the sidewall letters off his tires.
I had 245s on the front on a 9.5 -3 and it rubbed a tad....so the 245s might work in the front.
Old Jan 23, 2010 | 09:36 AM
  #5843
JonnyB504's Avatar
JonnyB504
this was also 245/40s
Old Jan 23, 2010 | 09:38 AM
  #5844
350z2go's Avatar
350z2go
awesome thanks for your help i might do 245 275 setup hopefully it would work and it would be 35 series tires
Old Jan 23, 2010 | 09:51 AM
  #5845
350z2go's Avatar
350z2go
i cant tell where the front is rubbing but a smaller tire would def help
Old Jan 23, 2010 | 10:05 AM
  #5846
JonnyB504's Avatar
JonnyB504
Originally Posted by JonnyB504
Maybe this can help you out.
245 on a 9.5
225 on a 9.5
I posed this a few pages back...the topis9.5 -3 with a 245/40 and it rubbed a good bit
Old Jan 23, 2010 | 10:10 AM
  #5847
350z2go's Avatar
350z2go
ya? so what did you do? and did it rub on plastic?
Old Jan 23, 2010 | 12:53 PM
  #5848
BiggieB15's Avatar
BiggieB15
Originally Posted by Hydralisk
and BiggieB15, dont take this the wrong way but you have my FAVORITE "cheap" wheel set up!
thanks jajajajajajjja
Old Jan 23, 2010 | 01:35 PM
  #5849
Royal_T's Avatar
Royal_T
I Agree with Jonny,, Either Roll some more and do a little pull at the same time. Or lower tire size and more camber..
Old Jan 23, 2010 | 03:41 PM
  #5850
350z2go's Avatar
350z2go
can u roll the front?
Old Jan 23, 2010 | 03:42 PM
  #5851
350z2go's Avatar
350z2go
o i got 245 and 275's on the way to replace 255 and 285's
Old Jan 23, 2010 | 05:49 PM
  #5852
1985zcar's Avatar
1985zcar
Lalalalalalala
Old Jan 24, 2010 | 02:19 AM
  #5853
White0ngold's Avatar
White0ngold
just a quik question, because like i said earlier in the thread i really do plan on going this route wit my Z now as before i wanted to do an LS2 swap but nahhh,,.anyways i bought my Z with some 20's on and it wasnt my style to be on dubs and a really big deal for me was the weight of the 20s if anything thats prbly the main reason i sold them and got sum stock 18s, anyways back to the question, FOR YOU GUYS WITH REALLY MEAN OFFSETS AND HUGE LIPS; DO YOUR RIMS WEIGH ALOT? OR ARE/IS THERE SUCH THINGS AS HAVING A BIG LIP ON RIMS AND STILL BEING LIGHT AT THE SAMETIME, AND ROYAL-T CAN U PLEASE ANSWER THIS QUESTION TOO ON YOUR DPE'S (SINCE I'M REALLY CONSIDERING THOSE RIMS)
Old Jan 24, 2010 | 04:21 AM
  #5854
MrToeknee's Avatar
MrToeknee
in this picture I was running
245/35/20 +7 in the fronts with -1.8 camber
275/30/20 +0 in the rear with -3.5 camber
Fronts were perfect except on mild bumps i would rub this little part of the frame. But that was because I had 35 series tires on the 20" rim. With 19's you'll be fine.
235/30/20 -3 fronts with same camber
275/30/20 +0 rear with same camber
IMHO I think a 30 series tire seems way too thin. Scared to ride on bumpy roads because of my higher risk of getting my tire slashed/damaged somehow. If I had to do it again, I would go with the 245/35/20 again. I would have done more stretch in the rear but since I have the Vortech, I need more rubber to the ground.
Old Jan 24, 2010 | 05:58 AM
  #5855
350z2go's Avatar
350z2go
so u think 245 and 275 on 19's i'll be fine? then i'll run the same camber as you?
Old Jan 24, 2010 | 09:11 AM
  #5856
Fren-Z's Avatar
Fren-Z
No I don't care because I know I am a horrible speller. I am about to graduate with a 3.8 in Biology and go to Med School but I can't spell for ****. haha
Med school huh JonnyB? Thats cool man guess were kinda in the same boat trying to fix our cars and go to professional school. Just got my BS in Bio this past spring and hopefully getting into pharmacy school this fall, if so the Z gonna have to take a backseat for a few years..
Old Jan 24, 2010 | 10:30 AM
  #5857
MrToeknee's Avatar
MrToeknee
Your gonna be at 245/35/19 +2 in the front? Thats another 5mm's further out than my setup. Your gonna have to run at least -2 camber in the fronts. I maxed out my stock arms in the front and they got me at -1.8.
If you added a 10mm spacer in the front and a 15mm spacer in the rear it'll work with the same camber specs i have.
Old Jan 24, 2010 | 10:48 AM
  #5858
MrToeknee's Avatar
MrToeknee
These were when I was on tein s tech springs with a 10mm spacer on my front GTS's running 245's.
I believe I was at -1 camber in those shots.
These pictures are not meant to be shown as aggressive wheels or stretch tires. Just to show 350z2go and others what you will be looking like if he went with 10mm spacers.
You gonna have to stretch tire in the front if you wanna use the 15mm spacer. Just FYI
Back to the thread
my test fit with my temporary setup....
Old Jan 24, 2010 | 04:01 PM
  #5859
350z2go's Avatar
350z2go
i have a 15mm spacer in the front and goin with a 245 on a 9.5 wide wheel you think ima rub?
Old Jan 24, 2010 | 09:34 PM
  #5860
chad_z33's Avatar
chad_z33
lowered the car a bit more.
