Aggressive Wheels and Stretched Tires....Welcome
Old May 13, 2010 | 06:08 PM
  #9101
SuperBlack350z's Avatar
SuperBlack350z
Originally Posted by akks350z
cutting fenders is better then rolling if its done right...and by me
being in body shop for a bit, i will say that cutting out weld seams, you will lose all strength from the fenders.
Old May 13, 2010 | 06:45 PM
  #9102
ryaann's Avatar
ryaann
I got a 225 on a 10" right now
Old May 13, 2010 | 08:41 PM
  #9103
hatchboi's Avatar
hatchboi
my black Z would be the one with the messed up fender pulled with the fenders cut. i personally dont think nothing is wrong with cut fenders as long as you dont plan on going with very aggressive offset. if you do go very aggressive then you will need to pull the fenders and you will run into problems since you lose the strength in you fenders. i didnt know anything about fitment at the time so i messed everything up. no worries next time you see pictures of my Z all will be fixed
Old May 13, 2010 | 09:03 PM
  #9104
Fren-Z's Avatar
Fren-Z
Hatchboi how much negative camber are you running?
Old May 13, 2010 | 09:22 PM
  #9105
MrToeknee's Avatar
MrToeknee
If I recall correctly he once told me -6.
I FINALLY installed my SPC rear camber arms and got an alignment. I was at -4.5 but now i'm at -5 camber. All that mattered to me was making sure my toe was in spec. Even after the alignment my driver side would rub, so i went home and did some more pulling. Sadly enough I pulled to the point where my fender roller couldnt handle and broke on me. But all in all, everything is good now. I might be raising up my car because I work downtown and my work ramp is not permitting me entry... Lol. I get STUCK!
Old May 13, 2010 | 09:24 PM
  #9106
MrToeknee's Avatar
MrToeknee
Originally Posted by 350ZToeRing
Do you not think 255 is playing it safe? I would have said 265 at least if not 275....
I was gonna do 255 on my 12" but I decided not to. I think its a little too much stretch for me. But it will def work. Just a preference.
Old May 13, 2010 | 09:25 PM
  #9107
MrToeknee's Avatar
MrToeknee
Oh yeah, and another thing.. When I was getting aligned, the guy let me go down to get eye level with the wheel and see how it was sitting.. OMFG, only half of my tire was touching the ground.
Old May 13, 2010 | 11:36 PM
  #9108
iLLest_Z's Avatar
iLLest_Z
Old May 13, 2010 | 11:59 PM
  #9109
evil350zdriver's Avatar
evil350zdriver
This makes me miss my EVO....dam!
Old May 14, 2010 | 12:13 AM
  #9110
bluevelvet's Avatar
bluevelvet
is this considered aggressive or nay?
Old May 14, 2010 | 12:29 AM
  #9111
evil350zdriver
^ Bluevelvet that looks SICK!!!! the color and wheels dam!!! just go lower and u got money!!!
Old May 14, 2010 | 01:03 AM
  #9112
joe645733's Avatar
joe645733
what kind've wheels are those? can't see from the caps.
Old May 14, 2010 | 03:08 AM
  #9113
ryaann's Avatar
ryaann
looks like ce28n
Old May 14, 2010 | 03:19 AM
  #9114
starve's Avatar
starve
Bluevelvet, what color is your G? Is that some kind of candy color?
Old May 14, 2010 | 04:17 AM
  #9115
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
http://www.ssr-wheels.com/wheels/sp3_181920.asp
Old May 14, 2010 | 05:31 AM
  #9116
07_z33's Avatar
07_z33
Damn, that g35 is baller!!! That bbk is sick
Old May 14, 2010 | 05:38 AM
  #9117
Toby-22's Avatar
Toby-22
those aren't CE28s, kinda look like SSRs to me....
Old May 14, 2010 | 06:13 AM
  #9118
vex008's Avatar
vex008
nice job with the G there bluevelvet.
sick setup
what are the specs on the wheels and tires?
Old May 14, 2010 | 06:39 AM
  #9119
jduet's Avatar
jduet
sick setup
From the fat tire thread:
For those wondering
20X9.5 +0
20X11 +3
255/30
285/30
Old May 14, 2010 | 07:12 AM
  #9120
ryanmac516's Avatar
ryanmac516
i like boobies
where were you able to get on an alignment rack around nola with removing your entire body kit
