Aggressive Wheels and Stretched Tires....Welcome
Old Oct 11, 2010 | 08:58 PM
  #11961
350z_Boi's Avatar
350z_Boi
Originally Posted by Max-G
camber doesn't actually cause the tire to wear at an accelerated rate. it just causes uneven wear from the inner and outer sides of the tire (because with negative camber the inner edge of the tire is in contact with the ground more than the outer edge). when the inner side gets worn, just switch the tire to the other side of the car and you're good. toe is what causes accelerated wear. it also depends on what tread ware the tires are. i think i'd get about 30,000-40,000 miles out of my current tires if i was planning on having them for that long...
thanks max. I was wondering does your outer tire rubs on your fender when you hit the bumps or dips? Mines rub on the outter tire on the rears. My fronts is just right. Should I pull the fender more or that's just normal?
Old Oct 11, 2010 | 09:54 PM
  #11962
Max-G's Avatar
Max-G
it depends on how bad they're rubbing. if it's taking chunks out of your tire, yes. if it's just rubbing the writing off your sidewall, no. post up some pics!
Old Oct 12, 2010 | 09:52 AM
  #11963
350z_Boi's Avatar
350z_Boi
For those who are running the stance gr+ coils. How stiff is your guys coil set to for daily driven? How much clicks in the front and the rear? Mines are set to 12 front, 6 rear. Or should I go more?
Old Oct 12, 2010 | 10:34 AM
  #11964
vinniePOOH's Avatar
vinniePOOH
is it just me that see's a page 599 but wont let you go to that page?
Old Oct 12, 2010 | 11:10 AM
  #11965
litoflow's Avatar
litoflow
^^vinnie is not only you. you should check out the "look what i got today" thread in the media side. lol they got like 5 pages ahead lol
I got mine set at full stiff in the rear and half in the front and ride is really good. you just gotta set it to where you like it the most.
Old Oct 12, 2010 | 11:35 AM
  #11966
350z_Boi's Avatar
350z_Boi
thanks bro. I'm just trying to prevent the rubbing on the rear do to small bumps and dips on the roads. It rubs more I guess cause of the stiffness on my rears. It's on half. I should consider to put it to full on stiffer probably set it to 10 clicks. My fronts are already at 12 clicks and it's pretty stiff and it helps a lot and less rubbing.
Old Oct 12, 2010 | 12:12 PM
  #11967
ryaann's Avatar
ryaann
my buddy who sold his Z, now has my old DPE ST-10's for sale
0 offset all around - 19x10 and 19x11 - gloss lip - matte face
General exclaim's
225/35
245/35
Let me know if anyone's interested!
Check my car in my profile for pics
Old Oct 12, 2010 | 12:16 PM
  #11968
ryaann's Avatar
ryaann
Just send me a pm if you are *
Old Oct 12, 2010 | 12:27 PM
  #11969
J's 350z!'s Avatar
J's 350z!
My fronts are full stiffness and my rear are at 9clicks but I need to make it more cause it rubs on my setup
Old Oct 12, 2010 | 02:06 PM
  #11970
350z_Boi's Avatar
350z_Boi
Thanks j.. I might go with 12 clicks on the rears and the front probably Max it. 11-12 should be good for the rears? Driving a slammed car with shitty roads sucks but low is a life style. Lol
Old Oct 12, 2010 | 03:06 PM
  #11971
litoflow's Avatar
litoflow
I say stay away from maxing out ur fronts, reason been is u have the engine and u need some suspension travel up front more than u need in the rear. I try to take care of the engine better than my fenders rubbing even tho I do not rub anymore. Remember the stiffer your suspension is the harder the engine feels the bumps. Maybe im wrong but that is how I see it so if u think different let me know.
Old Oct 12, 2010 | 03:13 PM
  #11972
350z_Boi's Avatar
350z_Boi
^^ true
Old Oct 12, 2010 | 03:21 PM
  #11973
fart_canon's Avatar
fart_canon
Originally Posted by Jose2008Z
Did some digging...more info can be found on this vette here:
http://forums.corvetteforum.com/c6-c...ykits-com.html
Badass car... Wheels are:
Brand: 360 Forged
Style: Concave Mesh
Size: F: 20x10.5" with 285/25-20 / R: 20x13" with 345/25-20
thank you for the information amigo!
Old Oct 12, 2010 | 04:21 PM
  #11974
Max-G's Avatar
Max-G
i don't think i've ever heard of someone throwing a rod because of hitting a pot hole. i'd rather have stiff suspension up front to keep my oil pan from smashing the ground. i think the worst that could happen is breaking an engine mount, but i highly doubt stiff spring rates could do that on their own. i daily drove my 240 with gr+ pro ssd's (12k/10k) at 3/4 stiff for a year and had no problems. i'm sure the z can easily compensate for 12k/5k at full stiff being that it's 800lbs heavier...
Old Oct 12, 2010 | 05:06 PM
  #11975
litoflow's Avatar
litoflow
No more Teasers. Welcome to the real Deal. Thanks to Quan and Don for the pictures...Video to come soon. and i might throw in a slam 240 with an rb26 for the drifting side of the video...we'll see.
Old Oct 12, 2010 | 05:42 PM
  #11976
jemeister's Avatar
jemeister
^^Omfg that is too hot!!!
Old Oct 12, 2010 | 05:51 PM
  #11977
512_Z's Avatar
512_Z
LOVIN THE NEW LOOK litoflow.... sick pics congrats
Old Oct 12, 2010 | 05:55 PM
  #11978
Barnabas's Avatar
Barnabas
National Z Club President
litoflow your car is amazing I love it
Old Oct 12, 2010 | 06:08 PM
  #11979
jaaf's Avatar
jaaf
fender work is perfection! looks sick bro
Old Oct 12, 2010 | 06:09 PM
  #11980
JonnyB504's Avatar
JonnyB504
Litoflow what is the specs again on the wheels/tires?
