Aggressive Wheels and Stretched Tires....Welcome
Old Nov 6, 2010 | 05:17 PM
  #12481
litoflow's Avatar
litoflow
I wouldn't get rear toe bolts, i would get toe arms instead.
Old Nov 6, 2010 | 06:00 PM
  #12482
Royal_T's Avatar
Royal_T
^^ I agree
Old Nov 6, 2010 | 07:27 PM
  #12483
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by fatboy.yoshi
wussup with the caster?
his caster issue, which will also cause his camber difference is a torn compression rod bushing..
see here:
https://my350z.com/forum/8767332-post16701.html
any lowered car needs those bushings........amazing that spl got them out for us....
-J
Old Nov 7, 2010 | 02:02 PM
  #12484
350z_Boi's Avatar
350z_Boi
Anyone purchase camber kits or toe links from battleversion?
Old Nov 7, 2010 | 03:56 PM
  #12485
CORNELL's Avatar
CORNELL
see here:
-J
J i agree 100% with you his caster is off due to the compression bushing. before repalcing mine i didn't think they could be that bad, until adjusting the front height one day i pushed down on the upper a-arm and saw my bushing was far more than just torn.
all should know that your front specs should not be identical left to right. if they were you would pull hard right(really hard).
1. manufacturers understand we drive on the right side of the road here and therefore design slight pull to the right to keep from hitting oncoming traffic during failure.
2. roads are designed with what is called a "crown" so that the highest point is the center sloping down to the sides for rain drainage naturally guiding the car right.
both of these things are factored into the alignment if your tech is experienced. cross-caster and cross-camber correct these variable to give the customer a straighter feel when letting go of the wheel.
Old Nov 7, 2010 | 04:16 PM
  #12486
BEBO'S ZEE's Avatar
BEBO'S ZEE
I spotted this in SD, didn't realize who it was until I saw the wheels. I like what you did with the front lip and grill
Old Nov 7, 2010 | 04:47 PM
  #12487
fatboy.yoshi's Avatar
fatboy.yoshi
see here:
-J
thanks for the heads up, maybe i should look into getting them soon...
Old Nov 7, 2010 | 06:41 PM
  #12488
Amoney47's Avatar
Amoney47
Old Nov 7, 2010 | 08:09 PM
  #12489
fatboy.yoshi
looks good, nice garage heheh
Old Nov 7, 2010 | 08:37 PM
  #12490
theianmcdougall's Avatar
theianmcdougall
amoney take that ugly rear window wiper off
Old Nov 7, 2010 | 09:35 PM
  #12491
-miltdoggie-'s Avatar
-miltdoggie-
this is what a cambered sc, 285/30 stretched on a 19x13, with a slight pull look like??? SICK!
one of my 19x12 too!! lol
Old Nov 7, 2010 | 10:36 PM
  #12492
KingBaby's Avatar
KingBaby
Hardest Setting
jesus!
you must know your roads for that...
seen a suby guy chip a huge piece off the fender...
nice though make me wanna follow suit...
Old Nov 8, 2010 | 04:32 AM
  #12493
litoflow's Avatar
litoflow
Damn sexy milt! Amoney ur rear shot is nice! Wiper off and is money
Running for stan e of the month. If u guys would like to show some love, pleased do
http://www.stancenation.com/forum/vi...t=1922&start=0
Thank you!
Old Nov 8, 2010 | 04:58 AM
  #12494
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by CORNELL
J i agree 100% with you his caster is off due to the compression bushing. before replacing mine i didn't think they could be that bad, until adjusting the front height one day i pushed down on the upper a-arm and saw my bushing was far more than just torn.
yep.............ALL of you guys........get a flash light onto your compression rod bushing and move the wheel a bit.........you will all see your bushings are TORN to hell...
look for this at a bare minimum:
REASON FOR REPLACEMENT - TORN!!!
HERE IS THE DAMAGE: TORN COMPRESSION ARM BUSHING, IE BAD CASTER!
let me know..
Everyone review here: - SPL DIY INSTALL on compression rod bushing:
https://my350z.com/forum/brakes-and-...g-install.html
-J
Old Nov 8, 2010 | 05:29 AM
  #12495
litoflow's Avatar
litoflow
Thank you J! Im gonna check mine when i get back
Old Nov 8, 2010 | 05:38 AM
  #12496
vex008's Avatar
vex008
Thank you!
voted - your at 42% in the lead with the civic in 2nd with 31%
Old Nov 8, 2010 | 06:00 AM
  #12497
JasonZ-YA's Avatar
JasonZ-YA
also understand that the transverse link inner bushing would be next.........if not already gone as well...
-J
Old Nov 8, 2010 | 07:15 AM
  #12498
ryaann's Avatar
ryaann
voted for you manny!
Old Nov 8, 2010 | 07:19 AM
  #12499
350z_Boi's Avatar
350z_Boi
Damn milt is killing it again! Amoney! Sickness...
Old Nov 8, 2010 | 01:45 PM
  #12500
JonnyB504's Avatar
JonnyB504
HR test pipe installs ownz DE install!
So I can't get the back bolt on the driver side of the 'cat' for nothing! Neither can two exhaust shops. Its completely rusted in there apparently and from trying and trying with regular sockets then stripped nuts sockets....its even MORE stripped. I can't believe it is being this difficult.
*BTW* the other back bolt on the passanger side actually snapped when I was trying to break it loose. Regardless I did not care because the 'cat' still came off.
Any ideas people? The second exhaust shop said he could get it if he dropped the headers......for 350$. F*ck that! I don't care how destroyed the 'cat' gets. Im thinking of maybe prying on the cat to get this bolt to snap also but I don't want to destroy anything else.
Thanks for your input!
