Aggressive Wheels and Stretched Tires....Welcome
Old Dec 6, 2010 | 12:17 PM
  #12901
fatboy.yoshi's Avatar
fatboy.yoshi
For those who are wondering, you can get stiff setups through stance, of course they will advise u otherwise but just let them know what u are wanting
Old Dec 6, 2010 | 12:41 PM
  #12902
Amoney47's Avatar
Amoney47
Originally Posted by zlatan
What's your camber at here?
Did you really re-quote the whole post when its like a couple posts up?
C'mon man SMH.
Old Dec 6, 2010 | 06:27 PM
  #12903
zlatan's Avatar
zlatan
C'mon man SMH.
The sexyness of the car deserved it good sir.
Old Dec 6, 2010 | 09:54 PM
  #12904
Amoney47's Avatar
Amoney47
lol okay ill give you that
Old Dec 6, 2010 | 11:01 PM
  #12905
evil350zdriver's Avatar
evil350zdriver
lol! thnks guyz....should have them on by wed or thursday!
Old Dec 7, 2010 | 07:07 AM
  #12906
scotts300's Avatar
scotts300
Originally Posted by 350DAN
^^^when i got my alignment it was at -3, but to be honest it looks like its moved itself from being driven for a while now. i'd say it is at -4 or -5 but i have to go to a shop and find out exactly. i'll get a better shot later today, the edge of the tire is off the ground
Why/how would it "move itself"? It is at least -5. I copied/pasted your picture into art and drew rough lines to estimate and got 8 degrees. I don't believe it's -8, but it's well over -4 or -5.
Old Dec 7, 2010 | 07:30 AM
  #12907
350DAN's Avatar
350DAN
what tires are you going with??
this worries me, i don't know exactly how the camber became so negative cuz i know it was -3 after i got the fenders pulled, now it just looks more angled......oh, well when i got my alignment i had the old tires that had camber wear on the inside, and i recently had the new tires installed so now that would make more sense as to why the angle is different...so now i guess its -4 or -5....damn
Old Dec 7, 2010 | 09:39 AM
  #12908
350z_Boi's Avatar
350z_Boi
Dan you running stock camber?
Old Dec 7, 2010 | 12:54 PM
  #12909
03threefiftyz's Avatar
03threefiftyz
Agree.....that camber is atleast -5. It looks perhaps more than that. If your camber has moved from -3 to -6ish.....you have an issue.
Old Dec 7, 2010 | 01:56 PM
  #12910
350DAN's Avatar
350DAN
no sir i have the eibach camber kit along with the oem spring bucket set up for the coilovers
yea i think that more negative camber occurred due to my new tires
Old Dec 7, 2010 | 02:10 PM
  #12911
03threefiftyz
Tires won't affect camber.......are you sure the eibach camber arms aren't defective or installed incorrectly?
Old Dec 7, 2010 | 02:20 PM
  #12912
350z_Boi's Avatar
350z_Boi
^^ camber are prone to slipping reguardless. My stock camber slipped on the right side and it was way off compared to the drivers side. That's why they make the lock out kit bolts to prevent slippage from your camber or your toe.
Old Dec 7, 2010 | 02:29 PM
  #12913
03threefiftyz
I get my car aligned 3 times a year as it sees 25-30 track/autocross events a year....it is never off more than .2-.3 in camber....toe can be a bit more out from time to time. The lockout bolts are for toe....not camber.
Old Dec 7, 2010 | 02:51 PM
  #12914
350Z_Al's Avatar
350Z_Al
The lockout bolts can be for camber as well if you've got camber arms.
It's possible that if he doesn't have lockout bolts, and the eccentric washers and bolts weren't tightened well that they've slipped significantly.
Old Dec 7, 2010 | 02:55 PM
  #12915
03threefiftyz
I forgot so many run true coil-over here.....If those bolts came loose as low (thus force) as he is the bolt would likely come off or shear completely. Thing is though......it's unlikely both sides would come loose so uniformly.
Old Dec 7, 2010 | 03:00 PM
  #12916
scotts300's Avatar
scotts300
Absolutely.
Old Dec 7, 2010 | 03:42 PM
  #12917
350DAN's Avatar
350DAN
^^^agreed
i also noticed my driver side toe is angled at -1 and the driver side is at 0
and i do not have the lock in bolts extra to help increase positive camber, i don't think it's needed at this point since my fenders are pulled the way they are
Old Dec 7, 2010 | 03:51 PM
  #12918
03threefiftyz
^^^agreed
What do you mean by -1? An inch? A mm? You must have a stellar eye. I'd recommend taking the car to a reputable alignment shop and having it given a once over. Sounds like you got a very poor alignment at the last place. I know for a fact I would not let some one leave with the rear tires looking like that, but it's the trend down there. I hate, and hesitate, to bring this up in here, but having that extra load (tons of camber) on an inside sidewall that is already had its integrity distorted cannot be good. That said....if you can get the camber back in check (-3?) you would be much better off, but it wouldn't look as cool to some.
Old Dec 7, 2010 | 04:42 PM
  #12919
350DAN's Avatar
350DAN
you wanna come down here and pay for my alignment?
i know what needs to be done i don't need someone else telling me otherwise.
i have my wheels cambered so i can have clearance under my pulled fenders so i can ride even lower. it's still a work in progress and i have bills to pay so it won't be fixed the way you're expecting it to for a while
Old Dec 7, 2010 | 05:33 PM
  #12920
litoflow's Avatar
litoflow
hey man, we still racing against each other at the track next year? pm me with info when u get it all set up btw i wont be NA in 2 weeks...
twins built coming...
btw i think Dan gets it with the camber. -3 will b perfect, im sure he is from -5 to -7, just how i was at -7.3 once and thought i was at -4 or so. im sure he ill fix it when the time comes though.
lets all cool off and let opinions be what the wanna be. we all tring to help each other here thats all. lol
